Serial on Adafruit ESP32-S2 TFT Feather
williamgill
Post by williamgill »
I have a Adafruit ESP32-S2 TFT Feather that I'd like to use to control a DRA818 radio. The serial didn't seem to be working so I tried a loop back demo, this also doesn't seem to work. Is there something special about this board (are the serial ports already in use by the neo pixel and the TFT?). Below complies and spits out "test" every 3 seconds.
#include <HardwareSerial.h>
HardwareSerial S2(1);
HardwareSerial S3(2);
  // put your setup code here, to run once:
  Serial.begin(9600);
  S2.begin(9600, SERIAL_8N1, 9, 10);  //tx, rx
  S3.begin(9600, SERIAL_8N1, 11, 12);
      delay(3000);
      Serial.println("test");
      S3.write("hello");
      while(S2.available()){
        char RxChar = S2.read();
        Serial.print(RxChar);
adafruit_support_carter
Re: Serial on Adafruit ESP32-S2 TFT Feather
I've reproduced this and think it's an issue with the ESP32 core define for this board. Fixing that will require some flow time to get the changes into the ESP32 core.
As a temporary workaround, can manually configure Serial1 on the TX RX pins using:
  Serial1.begin(9600);
  Serial1.setPins(2, 1);
in setup().
Here's a complete example sketch that should generate some simple output:
int count = 0;
  Serial1.println(count++);
  delay(500);
NOTE it's Serial1, not Serial. Serial is what goes over the USB port, which is not the same as the TX/RX pins.
williamgill
Perfect! I used .setPins and am now talking to the radio as expected. I had never seen .setPins anywhere before, thank you for setting me in that direction.
hathach
Post by hathach »
we made an PR to fix this and merged to arduino-esp32. This issue should be fixed in the next arduino-esp32 core release https://github.com/espressif/arduino-esp32/pull/7680.
Return to “Arduino”
