Hello!
Some of my high school engineering students are making snowglobes with the Adafruit snowglobe kits using the circuit playground express.
https://learn.adafruit.com/make-a-snowg ... v0QAvD_BwE
Everything is going great except that the volume of the music is so low it cannot be heard inside the snowglobe enclosure. The volume does not seem to get louder or softer with the volume block, which we have tried setting between 50-200.
Do you have any suggestions?
Thanks for any help you can give me. . . Susan
circuit playground music volume issue
Re: circuit playground music volume issue
The tiny on-board speaker does not have much power. And having it in a sealed space does not help.
You could try drilling some holes around the edges of the cap and adding some feet to raise it off the surface of the table. That would give a better path for the sound to get out.
The audio signal is also available on pin A0. So you could connect that to an external amplifier & speaker such as this one: https://www.adafruit.com/product/3885
- zackboston
Thank you! I am ordering a few of the external amplifiers you suggested. I just solder them to pin A0, Vout and ground, right?
How do I code them in MakeCode? We have all the music blocks already coded.
Should not need to change your code at all. A0 is the same signal that is currently going to the on-board speaker.
- zackboston
supercool! thank you. . . you will make the juniors at my vocational technical high school in Boston very very happy!!!
