Trinket 5V (16MHz) & SSD_1306 OLED - Can't Compile "Wire.h"
tszawars
Post by tszawars »
Hi everyone,
I am trying to use a Trinket 5V, 16MHz to make something show up on an SSD_1306 OLED display.
It is using I2C communication, so coming from the display I have SDA wired to pin 0 and SCK wired to pin 2 on the Trinket M0. I also have 5.6K pull-ups to Vcc (3.3V) on both SDA and SCK.
Here is my code:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET     -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define LOGO_HEIGHT   16
#define LOGO_WIDTH    16
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    for(;;);
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(2,0);
display.println(" HELLO ");
delay(100);
display.display();
The code works fine on Arduino Nano and Micro (I tested it). I cannot get it to work on the Trinket.
When I try to compile to Trinket, I get this error:
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
                 from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
                 from sketch\sketch_jan06b.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In member function 'void SPISettings::init_AlwaysInline(uint32_t, uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:16: error: 'SPE' was not declared in this scope
     spcr = _BV(SPE) | _BV(MSTR) | ((bitOrder == LSBFIRST) ? _BV(DORD) : 0) |
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:16: note: suggested alternative: 'SPH'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:27: error: 'MSTR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:27: note: suggested alternative: 'PSTR'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:65: error: 'DORD' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:146:65: note: suggested alternative: 'DDRB'
In file included from C:\Users\TSZAW\Documents\Arduino\sketch_jan06b\sketch_jan06b.ino:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::beginTransaction(SPISettings)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:203:5: error: 'SPCR' was not declared in this scope
     SPCR = settings.spcr;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:203:5: note: suggested alternative: 'EECR'
     EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:204:5: error: 'SPSR' was not declared in this scope
     SPSR = settings.spsr;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:204:5: note: suggested alternative: 'ACSR'
     ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static uint8_t SPIClass::transfer(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:209:5: error: 'SPDR' was not declared in this scope
     SPDR = data;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:209:5: note: suggested alternative: 'EEDR'
     SPDR = data;
     EEDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:217:14: error: 'SPSR' was not declared in this scope
     while (!(SPSR & _BV(SPIF))) ; // wait
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:217:14: note: suggested alternative: 'ACSR'
              ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:217:25: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:217:25: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static uint16_t SPIClass::transfer16(uint16_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:223:11: error: 'SPCR' was not declared in this scope
     if (!(SPCR & _BV(DORD))) {
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:223:11: note: suggested alternative: 'EECR'
           EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:223:22: error: 'DORD' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:223:22: note: suggested alternative: 'DDRB'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:224:7: error: 'SPDR' was not declared in this scope
       SPDR = in.msb;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:224:7: note: suggested alternative: 'EEDR'
       SPDR = in.msb;
       EEDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:226:16: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:226:16: note: suggested alternative: 'ACSR'
                ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:226:27: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:226:27: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:230:16: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:230:16: note: suggested alternative: 'ACSR'
                ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:230:27: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:230:27: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:233:7: error: 'SPDR' was not declared in this scope
       SPDR = in.lsb;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:233:7: note: suggested alternative: 'EEDR'
       SPDR = in.lsb;
       EEDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:235:16: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:235:16: note: suggested alternative: 'ACSR'
                ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:235:27: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:235:27: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:239:16: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:239:16: note: suggested alternative: 'ACSR'
                ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:239:27: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:239:27: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::transfer(void*, size_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:247:5: error: 'SPDR' was not declared in this scope
     SPDR = *p;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:247:5: note: suggested alternative: 'EEDR'
     SPDR = *p;
     EEDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:250:16: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:250:16: note: suggested alternative: 'ACSR'
                ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:250:27: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:250:27: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:255:14: error: 'SPSR' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:255:14: note: suggested alternative: 'ACSR'
              ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:255:25: error: 'SPIF' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:255:25: note: suggested alternative: 'WDIF'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::setBitOrder(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:292:31: error: 'SPCR' was not declared in this scope
     if (bitOrder == LSBFIRST) SPCR |= _BV(DORD);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:292:31: note: suggested alternative: 'EECR'
                               EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:292:43: error: 'DORD' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:292:43: note: suggested alternative: 'DDRB'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:293:10: error: 'SPCR' was not declared in this scope
     else SPCR &= ~(_BV(DORD));
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:293:10: note: suggested alternative: 'EECR'
          EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:293:24: error: 'DORD' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:293:24: note: suggested alternative: 'DDRB'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::setDataMode(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:298:5: error: 'SPCR' was not declared in this scope
     SPCR = (SPCR & ~SPI_MODE_MASK) | dataMode;
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:298:5: note: suggested alternative: 'EECR'
     EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::setClockDivider(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:303:5: error: 'SPCR' was not declared in this scope
     SPCR = (SPCR & ~SPI_CLOCK_MASK) | (clockDiv & SPI_CLOCK_MASK);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:303:5: note: suggested alternative: 'EECR'
     EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:304:5: error: 'SPSR' was not declared in this scope
     SPSR = (SPSR & ~SPI_2XCLOCK_MASK) | ((clockDiv >> 2) & SPI_2XCLOCK_MASK);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:304:5: note: suggested alternative: 'ACSR'
     ACSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::attachInterrupt()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:309:42: error: 'SPCR' was not declared in this scope
   inline static void attachInterrupt() { SPCR |= _BV(SPIE); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:309:42: note: suggested alternative: 'EECR'
                                          EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:309:54: error: 'SPIE' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:309:54: note: suggested alternative: 'ACIE'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h: In static member function 'static void SPIClass::detachInterrupt()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:310:42: error: 'SPCR' was not declared in this scope
   inline static void detachInterrupt() { SPCR &= ~_BV(SPIE); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:310:42: note: suggested alternative: 'EECR'
                                          EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:310:55: error: 'SPIE' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src/SPI.h:310:55: note: suggested alternative: 'ACIE'
Multiple libraries were found for "Wire.h"
 Used: C:\Users\TSZAW\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.15\libraries\Wire
 Not used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
Error compiling for board Adafruit Trinket (ATtiny85 @ 16MHz).
It looks like Arduino IDE is trying to open up two Wire.h header files (the Adafruit one, and the original Arduino one). But I'm not sure why the exact same code compiles fine on the other Arduino AVR boards, just not the Trinket...
That's what I understood anyway from this snippet of the error message:
exit status 1
Does anyone have any idea why it might not be working?
Thanks in advance.
Re: Trinket 5V (16MHz) & SSD_1306 OLED - Can't Compile "Wire.h"
Those are two different processors. The Trinket 5v is an ATTiny 85. The Trinket M0 is an ATSAMD21. Which one are you using?
tszawars
Post by tszawars »
Sorry I meant to say Trinket 5V, 16MHz across the topic.
The Wire Library does not support the ATTiny85 processor. For that you need to use the TinyWireM library:
https://github.com/adafruit/TinyWireM
