ITSY BITSY 32u4 5v No serial port created
na103
Post by na103 »
Hello
I bought some day ago from digikey, brand new and never used before, have same problem described in this post.
viewtopic.php?t=195170
is broken ?
Franklin97355
Re: ITSY BITSY 32u4 5v No serial port created
Post by Franklin97355 »
Have you done the same tests? Have you tested the cable to make sure it is a data cable rather than a charging cable? Let us know what tests you have done and what were the results.
na103
Post by na103 »
yes of course it is the correct usb cable that I also use for other devices.
it is shown in the windows device manager as ATm32U4DFU and no led lights up.
same result on 3 different computers with windows 10. on linux lsusb seen as ATm32U4DFU but no ttyUSB device is spawned.
Franklin97355
OK, let's replace it. Contact [email protected] with a link to this thread and they will get you another.
Return to “Itsy Bitsy Boards”
