Junk data received from UART
PierreDeQuebec
Posts: 96 Joined: Sun Jul 25, 2021 3:26 pm
Post
by PierreDeQuebec » Sun Jan 08, 2023 10:23 am
I have a setup with an Ultimate GPS Logging Shield board mounted on a Metro M4 AirLift Lite board. The assembly works well with a baud rate of 9600 bauds for the UART. The UART is connected in 'Hardware Serial' mode as it should be. But for other possible baud rate values, I get 'Unicode Error' error messages with garbage data similar to this:
UnicodeError
b'\x10\x0c\x92\x90\x92l\x12bp\x82\x0cb\x1cl\x8c\x8e\x82rl\x10\xec\x90\x92\x90\x90\x80pl\x0c\x8ell\x0c\x8cb\x0c\x0c\x0cb\x8e\x8e\x8er|\x8c\x8e\x1c\x82\xec\x0cblb\xec\x8ep\x80\x0c\x8cbl\x8c\x8e\x0cb\x92bpp\x0c\xec\x8ebp|\x8c\x0c\x8eb\x8ep|\xec\x0cb\x8eplb\x1c\xe0\x8cb\x8eb\x8ep\x0cb\x12\x9c\xecl`\x02\x10\xec\x90\x12lrr\x82bp\x90\x0cll\x0c\x8cb\x0c\x0c\x0cb\x80p\x0c\x8e\x8e\x8er|\x8c\x8e\x1c\x82\xec\x0cblb\xec\x8ep\x80\x0c\x8cbl\x8c\x8e\x0cb\x92b\x8cbp\x80\x0cb\x1c\x9c\xec\x8cb\x8e\x8eb\x0c\x0cl\x8c\xec\x0cbbb\x80l\xec\x8e\x80rl'
I traced the origin of the error message in the adafruit _gps library to the _read_sentence method.
Can you help me figure out what's wrong?
Thank you
Pierre
mikeysklar
Posts: 13936 Joined: Mon Aug 01, 2016 8:10 pm
Post
by mikeysklar » Sun Jan 08, 2023 2:44 pm
Pierre,
Are you using the Arduino libraries?
Can you post the code you are using to set the baudrate for the Ultimate GPS and serial speed on the Metro M4?
Was the next baudrate you tried 57,600?
PierreDeQuebec
Post
by PierreDeQuebec » Sun Jan 08, 2023 8:14 pm
Hi mikeysklar,
The command used is the following.
def _setup_gps(self):
if self.gps:
self.uart.deinit()
self.gps = None
_actual_uart_baudrate = self.uart_baudrate
_actual_timout = self.uart_timeout
if self.gps is None or self.uart_baudrate != _actual_uart_baudrate or self.uart_timeout != _actual_timout:
# Restart the UART and the GPS chip.
self.uart = busio.UART(self.gs_board.TX,
self.gs_board.RX,
baudrate=self.uart_baudrate,
timeout=self.uart_timeout)
self.gps = gps_mod.GPS(self.uart, debug=self.debug) # Use UART/pyserial
self.gps.send_command(self.sentences['PMTK314'])
# Initial sentences requirement (like RMC, GGA, GSA sentences).
gps_mod is an instance of the adafruit_gps CircuitPython library.
self.sentences is a dictionary of my own.
I just tried initializing the GPS with a baud rate of 56700 baud. The result follows.
UnicodeError
b'\x00\x00\x00\x00\xe0\xe0\xe0\x00\xe0\x00\xe0\xe0\xe0\xe0\x00\xe0\x00\xe0\xe0\x00\xe0\x00\xe0\x00\x00\xe0\x00\x00\x00\xe0\x00\x00\x00\x00\x00\xe0\xe0\x00\x00\xe0\x00\xe0\xe0\x00\xe0\xe0\xe0\x00\x00\xe0\x00\x00\x00\x00\xe0\x00\xe0\x00\xe0\xe0\xe0\x00\xe0\xe0\x00\xe0\xe0\x00\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\xe0\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\xe0\x00\xe0\x00\x00\x00\xe0\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\xe0\x00\xe0\xe0\xe0\xe0\x00\xe0\x00\xe0\x00\x00\x00\xe0\x00\x00\x00\x00\x00\x00\xe0\x00\xe0\x00\x00\x00\xe0\x00\xe0\x00\x00\xe0\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\x00\x00\x00\xe0\x00\xe0\xe0\x00\x00\xe0\x00\xe0\xe0\x00\xe0\x00\xe0\x00\xe0\xe0\xe0\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\xe0\x00\xe0\x00\xe0\x00\x00\xe0\x00\x00\xe0\xe0\x00\x00\xe0\x00\xe0\xe0\x00\xe0\xe0\x00\x00\xe0\x00\x00\x00\x00\xe0\x00\xe0\x00\xe0\xe0\x00\x00\xe0\xe0\xe0\xe0\x00\xe0\xe0\x00\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\xe0\x00\xe0\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\xe0\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\xe0\x00\xe0\x00\x00\x00\xe0\xe0\x00\xe0\x00\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\xe0\x00\xe0\xe0\xe0\xe0\x00\xe0\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\x00\xe0\x00\xe0\x00\x00\xe0\xe0\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\xe0\xe0\x00\xe0\xe0\xe0\x00\x00\xe0\x00\x00\x00\xe0\x00\x00\x00\x00\xe0\x00\x00\x00\x00\x00\xe0\x00\x00\x00\xe0\x00\x00\xe0\x00\x00\xe0\x00\xe0\x00\xe0\x00\xe0\xe0\x00\xe0\xe0\x00\x00\x00\xe0\xe0\x00\x00\xe0\x00'
mikeysklar
Post
by mikeysklar » Mon Jan 09, 2023 2:14 pm
Can you post the code you are calling setup_gps() with and the printed NMEA string being sent?
It looks to me like you are only setting up the Metro for the correct baudrate, but not sending the necessary NMEA string to the Ultimate GPS to set it to 57600. The Ultimate GPS would be running at its default of 9600).
gps.send_command(b"PMTK251,57600")
