Yes, it's building, compiling is only one step.
Create it like creating any other directory. Windows probably has a "New Folder" command somewhere. I couldn't tell you where as I don't use Windows.
Why is my code saying "Error Compiling for Arduino Nano"
- dastels
- animefruit
Re: Why is my code saying "Error Compiling for Arduino Nano"
So I didn't know what you meant about creating a new directory but I did create a New Folder and dragged Tl10684400A (C:) into that as a new folder.
And when I uploaded the same code again I got the same exact error.
What should I do about that?
Also I just got this Weird Error on my Other Computer where I am not able to choose the Port.
The Port option just completely disappeared!
Can you also tell me how to fix that issue because it is a big problem?
I have a Picture of it Not Displaying the Port attached to this post.
I also have a Picture of How it is Supposed to Look when the Port is displayed.
- Port Shown 3.png (46.4 KiB) Viewed 141 times
- Port Not Shown!.jpg (559.93 KiB) Viewed 141 times
- dastels
I'm not completely sure what you mean but that doesn't sound like a reasonable thing to do. I'm surprised that would work.I did create a New Folder and dragged Tl10684400A (C:) into that as a new folder.
I'd mentioned that directories are also called folders in GUI file managers.
Reinstalling Arduino might help.
Huh.. I have never seen the port option disappear.
- animefruit
I tried Uninstalling the Arduino IDE to Reinstall it, but when I do it says that it will not let me keep my libraries within it.
I also have a picture of that attached to this post.
Do you know any way I can Reinstall the Arduino IDE without deleting all my past libraries with it?
Also I probably should have told you in the beginning that other code works on this computer and the other computer.
So it may not be a problem with my computer or the files on my computer.
Do you still think it is a problem with the computer or files on my computer?
- Delete Libraries.PNG (391.01 KiB) Viewed 131 times
- dastels
Hmm. Is everything up to date? All board support packages and libraries?
- animefruit
While the computer that has its port option disappeared I tried using another computer instead.
I am trying to use it for my other RFM69 Radio.
I used this article to try to download the Radiohead library:
https://learn.adafruit.com/adafruit-rfm ... 9-radio
I tried downloaded it from the zip from the green button shown in the image below.
I also tried downloading it from the zip from the GitHub.
I placed one Radiohead zip under libraries in my Arduino folder as shown in one of the images attached.
I also placed some of the Radiohead zips from GitHub in the libraries in my Arduino folder as well as more zips from the same green button as shown in another image attached.
And then in another image in the below post it shows how there is no RadioHead Example libraries that is displayed.
How could this be?
Did I do something wrong?
How can I fix this?
How could this be?
How can I fix this?
- Green Button.jpg (111.2 KiB) Viewed 127 times
- Inside Libraries.jpg (926.07 KiB) Viewed 127 times
- Under Libraries.jpg (755.64 KiB) Viewed 127 times
- animefruit
Here is the picture that shows that when I go to Examples there is no RadioHead Example libraries that is displayed.
Why is this?
Why is this?
- No RadioHead!.jpg (789.71 KiB) Viewed 127 times
- animefruit
How do I check if my libraries and support packages are up to date?
I couldn't find any answers on the web.
- dastels
You want the library folders in libraries, not libraries/New Folder.
Try to install libraries from within Arduino if possible.
In 1.8.*:
Sketch->Include Library->Manage Libraries...
Then in the Type dropdown pick Updatable
Tools->Board->Board Manager...
In 2.* it's easier. Open the library or board manager and select Updatable from the type dropdown.
In all the above cases you will have a list of items that should be updated. Click the Update button on each item.
In 1.8.*:
- animefruit
I did that and it had an option to Update the Arduino AVR Board library.
I updated it and still I got the same exact error.
Can you also tell me why my Radiohead Library isn’t showing up in my Examples on one of my other computers in my below post?
- dastels
I suspect it's because you have it inside a folder named New Folder and not directly in the libraries folder.
- animefruit
I don’t know how to delete the New Folder though.
I deleted it from my desktop display and now I can’t find it in the files.
Do you know how to find recently deleted files from the desktop display?
I don’t think deleting it from the desktop display means it is fully deleted.
- dastels
Look in the trash.
- animefruit
Ok. I will look in the trash.
Can you also tell me why my other computer isn’t showing RadioHead examples in one of my above posts?
- dastels
Likely the library isn't correctly installed and it can't find the examples.
