Feather Huzzah 8266 does not show in my boards
adafruit.io wippersnapper BETA support, discussions, and more!
CorlettT
Post by CorlettT »
Hi, I followed the instructions to install Wippersnapper, the board is connecting to wifi, but not getting registered with IO.
Serial output below, please let me know what I can do:
Adafruit.io WipperSnapper
-------Device Information-------
Firmware Version: 1.0.0-beta.57
Board ID: feather-esp8266
Adafruit.io User: XXXXX
WiFi Network: BANNED
MAC Address: 9C:9C:1F:45:63:DC
Generating device's MQTT topics...
Subscribing to device's MQTT topics...
Running Network FSM...
Attempting to connect to WiFi
Attempting to connect to WiFi...
CONNECTING
Attempting to connect to Adafruit IO...
Unable to connect to Adafruit IO MQTT, retrying in 3 seconds...
ERROR [WDT RESET]: ERROR: Unable to connect to Adafruit.IO MQTT, rebooting soon...
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffd40 end: 3fffffc0 offset: 01a0
3ffffee0: 3fffff20 00000002 3fff2fac 4020e83a
3ffffef0: 40100a1c 3fff2fac 00000002 4020e926
3fffff00: 3fff2fac 00000002 3fff2fac 4020a33d
3fffff10: 3fff2fac 3fff2b8c 3fff20f8 4020a43e
3fffff20: 3fff5c7c 003f003f 80000000 4021cac8
3fffff30: 00000001 00000001 3fff2fac 4021cbac
3fffff40: 39303232 00393639 3fff2d8c 3fff30ec
3fffff50: 3fff278c 3fff2fac 3fff20f8 4020a848
3fffff60: 00000000 00000001 3fff2fac 4021c908
3fffff70: 00000000 feefdc63 3fff20f8 3fff30ec
3fffff80: 0001c200 0000001c 00000000 3fff30ec
3fffff90: 3fffdad0 00000000 3fff20f8 402089a1
3fffffa0: feefeffe feefeffe 3fff30d8 4021db74
3fffffb0: feefeffe feefeffe 3ffe88bc 40101491
<<<stack<<<
mikeysklar
Re: Feather Huzzah 8266 does not show in my boards
Post by mikeysklar »
Did you try a hard reset as the Troubleshooting section suggests? Unplug the USB cord and plug it back in.
https://learn.adafruit.com/adafruit-fea ... aq-3120273
I don't see my board on Adafruit IO, it is stuck "Registering with Adafruit IO"
Try hard-resetting your board by unplugging it from USB power and plugging it back in.
Can you run this through the Exception Decoder?
Open a sketch and build it.
Upload the sketch and monitor the Serial port for Exceptions
When you get an Exception, open Tools > ESP Exception Decoder menu item. This will open a new window.
Paste the stack trace into the window's top pane and the result will show in the bottom.
Every time you enter new address or stack trace, the results will refresh
CorlettT
Post by CorlettT »
I'm running Arduino IDE 2.0.3, not seeing ESP Exception Decoder option in the Tools menu. Do I need to enable something?
mikeysklar
Okay, I think I see what is going on. You have not installed the necessary Arduino ESP8266 board package.
https://learn.adafruit.com/adafruit-huz ... ge-2571073
Install the ESP8266 Board Package
Enter http://arduino.esp8266.com/stable/packa ... index.json into Additional Board Manager URLs field in the Arduino v1.6.4+ preferences.
CorlettT
Post by CorlettT »
Hi Mikey, Thanks for the fast reply. Looks like something truly spooky is going on. Check out these screenshots, I have the ESP8266 package installed, and it lets me choose the correct board, but the ESP tools are not showing up in the Tools menu:
Screenshot 2023-01-10 at 5.51.36 PM.png (34.47 KiB) Viewed 714 times
Any thoughts on what could be up?
Also:
- Hard resetting by unplugging/replugging has no effect.
- I tried reinstalling Wippersnapper and changing the wifi to use my home system, rather than the one at work- I got exactly the same results.
Thanks-
Screenshot 2023-01-10 at 5.53.08 PM.png (270.54 KiB) Viewed 714 times
CorlettT
Post by CorlettT »
Installed Arduino IDE 2.0.3 on a different laptop, installed ESP8266 board definitions, still no ESP tools.
mikeysklar
There are at least two issues here:
1) If you want to use WipperSnapper then Arduino will be of no value. WipperSnapper has no compatibility with the Ardiuno IDE.
2) If you want to use the Arduino IDE with this Board Manager package back down the last stable Legacy release 1.8.19 (scroll down):
https://www.arduino.cc/en/software
CorlettT
Post by CorlettT »
I want to use Wippersnapper, if I can get it to work. I am using Arduino for the serial monitor, to see the errors Wippersnapper is reporting. Any ideas what these Wippersnapper errors mean, or how to correct the situation?
mikeysklar
You can use the earlier release of the Arduino IDE 1.8.19 to process the stack trace being generated. That should help with getting going with Wippersnapper.
CorlettT
Post by CorlettT »
I installed the legacy Arduino, and the ESP exception tool, which is a separate plugin now. It doesn't seem to want to process code directly from the upper window of a sketch- it pops up a file browser window demanding an .ELF file to open. Could you just cut/paste the stack info from my post into the tool on your end?
mikeysklar
I've contacted the WipperSnapper engineer @brentru about ELF files access for stack decoding.
brubell
Learn User Page
Post by brubell »
How did you install WipperSnapper on the ESP8266?
CorlettT
Post by CorlettT »
I used the firmware tool in Chrome, as found here: https://io.adafruit.com/CorlettT/wippersnapper/new/
CorlettT
Post by CorlettT »
More than a week since the last reply, so I'm going to uninstall WipperSnapper so I can use this board with Arduino. Maybe I'll give this another try next year.
brubell
Learn User Page
Post by brubell »
Would you be able to try https://adafruit.github.io/WipperSnappe ... er-esp8266, this will install the latest version of WipperSnapper (Beta 58) on your board. Please double-check the adafruit io credentials you enter in the uploader website, prior to uploading to your board.
If it does not work - and you're still having issues - please let me know so I can file a bug on our repository and try to reproduce it from my end. I have another pending ESP8266 issue and can work on addressing both at the same time.
Return to “Adafruit IO Wippersnapper Beta”
