Feather Huzzah 8266 does not show in my boards
- CorlettT
Re: Feather Huzzah 8266 does not show in my boards
I'll give it a try and report back
- CorlettT
Loaded the latest version, I get this (in Serial Monitor) no matter what I do:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v0006b5a0
~ld
tail 0
chksum 0x2e
tail 0
chksum 0x2b
csum 0x2b
v0006b5a0
~ld
- brubell
- Learn User Page
Ok, there's something wrong with the ESP8266 (could be either the firmware, filesystem, or the uploader). Someone else is having the same issue as you and I've gathered enough data to make a bug report.
https://github.com/adafruit/Adafruit_Wi ... issues/404
I'll try to reproduce this issue with the ESP8266 and will follow up both here and on the issue linked above.
- CorlettT
I have a couple duplicates of this build around from the same order, I'll try it with one of those to see if the issue is consistent
- brubell
- Learn User Page
Could you also try going into your Windows device manager and following the steps illustrated here to use an older version of the CP210x driver: https://github.com/espressif/esptool-js ... 1445188241
- CorlettT
I have a Mac, so I'd need to do that another way.
Since this issue started I have a new laptop with a fresh system install, so I'll try again and see if anything has changed.
- brubell
- Learn User Page
Hi, we were able to reproduce this error and found the bug. I just updated the uploader to use the correct file system size and have tested the fix locally on my Feather ESP8266.
This bug should be gone.
Please let me know on this thread if you are still experiencing the same problem.
