I have a V2 Featherwing connected to a TMC-2226 BOB on a breadboard. The driver drives a 200 step (12v, 350mA/phase) stepper motor https://www.adafruit.com/product/324.
The TMC-2226 uses a step and direction pin. It also has two microstep pins MS1 and MS2, which can be connected to GND and VCC_IO in different combinations to get different microstepping levels. However, the hardward-based selection of microsteps is limited to 4 microstepping options. The driver can do more, but I am having trouble finding any examples on how to do it. For example, I would like to see if I can signal the driver to do fullstep or 1/2 step. I've read the Trinamic documents on it, but a lot of it is beyond my level. I'll ask Trinamic tech support as well, but I thought I'd ask you guys first. Even if you have any leads for things I might search online, I'd appreciate any ideas. I am using Arduino IDE for it.
Stepper Driver
Re: Stepper Driver
I don't have any first-hand experience with configuring the advanced stepping options. But it involves communicating with the chip via the UART interface to set up the internal configuration registers.
Other than direct assistance from Trinamic, you might also try the RepRap forum, since a lot of the RepRap folks are using these drivers.
- forum_questions_1
Re: Stepper Driver
Ok, thanks Bill. I'll check that out.
- forum_questions_1
Re: Stepper Driver
Hi Bill,
Just an update - I finally got this working and was able to access the settings via hardware serial. There are a lot of settings available through this.
Also, thank you for the info you had in this recent post viewtopic.php?p=955293&hilit=ohms#p955293. I thought it was a good explanation about stepper motor power.
Re: Stepper Driver
Good to hear you got it working. And thanks for sharing your results.
