Raspberry Pi Zero W does not power on
inwerds
Post by inwerds »
Hi, all.
I received my kit earlier this week:
1 x Raspberry Pi Zero W[ID:3400] = $10.00
1 x Adafruit Raspberry Pi Zero Case[ID:3252] = $4.75
1 x 5V 2.5A Switching Power Supply with 20AWG MicroUSB Cable[ID:1995] =
$8.25
1 x SD/MicroSD Memory Card (8 GB SDHC)[ID:1294] = $9.95
And was up and running quickly with RPi OS Lite (installed via RPi Imager). Today, I unplugged the RPi to install it into the Adafruit case and two things happened.
  • 1. After putting it in the case, and plugging in the power from the supply listed above, the green LED on the RPi did not illuminate. I tried several different outlets and I tried different cables. It doesn't appear as though power is getting to the RPi
  • 2. Since the only thing that changed was that I put it into the case, I figured I would remove it and in doing so, the SD card got caught up on the case and broke.
Please LMK if you need photos or videos and/or if this is covered.
ETA: this is a headless config.
dastels
Re: Raspberry Pi Zero W does not power on
Post by dastels »
There are several articles in troubleshooting Pis. Start by have a look at https://support.thepihut.com/hc/en-us/a ... -is-faulty and https://learn.adafruit.com/raspberry-pi ... leshooting.
Be sure to take note of https://learn.adafruit.com/raspberry-pi ... ng/warning.
inwerds
Post by inwerds »
Hello - thank you for those links.
I will respond to each one.
dastels
Post by dastels »
Have you checked the power connector on the board? Did its connections to the board get damaged?
Can you apply power via the ground and 5v header pins? Either directly or through something like https://www.adafruit.com/product/3581.
inwerds
Post by inwerds »
From a visual inspection, everything looks "normal."
This is a $10 pi, so I'm unlikely to spend $8.50 on a workaround.
dastels
Post by dastels »
That's reasonable.
bidrohini
Post by bidrohini »
You can check these points: https://support.thepihut.com/hc/en-us/a ... -is-faulty
If nothing works, you can consider buying a pico next time:
https://www.theengineeringprojects.com/ ... sheet.html
