source: https://learn.adafruit.com/adafruit-io- ... et-connect
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
#esp32_cs = DigitalInOut(board.D9)
#esp32_ready = DigitalInOut(board.D10)
#esp32_reset = DigitalInOut(board.D5)
Has anyone got wifi working?
edit:
`dir(board)` returns the following
['__class__', '__name__', 'A0', 'A1', 'A2', 'A3', 'A4', 'A5', 'A6', 'A7', 'BOOT0', 'BUTTON', 'D0', 'D16', 'D17', 'D18', 'D35', 'D36', 'D37', 'D40', 'D41', 'D5', 'D6', 'D7', 'D8', 'D9', 'I2C', 'MISO', 'MOSI', 'NEOPIXEL', 'NEOPIXEL_POWER', 'RX', 'SCK', 'SCL', 'SCL1', 'SDA', 'SDA1', 'SPI', 'STEMMA_I2C', 'TX', 'UART', 'board_id']
and `board.board_id` is `adafruit_qtpy_esp32s2`
