I have a M4 that I'm trying to connect to my Wi-Fi network. I have double-checked the secrets.py file and it contains the correct SSID and password information. My code:
import time
import board
import displayio
import adafruit_display_text.label
from adafruit_matrixportal.matrixportal import MatrixPortal
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
matrixportal = MatrixPortal(status_neopixel=board.NEOPIXEL, bit_depth=4, debug=True)
TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
r = matrixportal.fetch(TEXT_URL)
print("Confirm text was retrieved? ", r)
When I run this, I sometimes connect with no issue. Other times, I get the following error:
Connecting to AP LinusSSID
Could not connect to internet ('No such ssid', b'LinusSSID')
I don't understand why it says "no such ssid" when it lists the correct SSID (LinusSSID). I also don't understand why the error lists b'LinusSSID' ... where did the "b" come from? If it helps, I'm connecting to a UniFi nano AP and my cellphone sitting right next to the M4 has 5 bars of Wi-Fi signal.
Thoughts?
Matrix Portal M4 spotty Wi-Fi connection
- mikeysklar
Re: Matrix Portal M4 spotty Wi-Fi connection
Have you updated the ESP32 firmware on your MatrixPortal M4?
https://learn.adafruit.com/upgrading-es ... t-firmware
If you are not already running the CircuitPython 8.00-Beta-6 release. I would recommend using that.
https://circuitpython.org/board/matrixportal_m4/
The internet connect page for the MatrixPortal M4 has sample code which includes the RSSI signal output. This could be helpful with the network scan to see the signal strength and you move try some physical rotation and placement adjustments to see how if effects signal.
https://learn.adafruit.com/adafruit-mat ... et-connect
- tarrant1704
I updated the ESP32 with the instructions you provided. I think that helped, so thank you!
- mikeysklar
Thank you for taking the time to do the update and the followup. Much appreciated.
