IR stopped working
- folmerbill
IR stopped working
I was using an IR remote and sensor to turn LEDs on and off, it worked just fine, then I desoldered everything and resoldered it in the housing for the final project, but now the IR doesn't work. Same pins, same code. I tried moving the pin, but still nothing. LEDs still work, but not IR. please help
Re: IR stopped working
If you post some photos showing all your soldering and connections, we can try to spot the problem.
