following the instruction reported https://learn.adafruit.com/adafruit-i2s ... iring-test I have connected two I2S microphones to a Raspberry Pi 3A+. The microphones are connected by wire about 20 cm long.
On the left channel I have this issue while the right cnannel is recorded correctly without any noise:
Also exchanging the microphone order between L and R, the result, doesn't change.
Some other details: sampling rate of 48 kHz with 24-bit resolution, 2 channel as obvious and 2^12 buffer.
Any idea to overcome this issue?
Two I2S MEMS microphones stereo record issue with Raspberry Pi 3a+
- frank984
- Immagine 2023-01-15 120537.png (18.76 KiB) Viewed 54 times
- mikeysklar
Re: Two I2S MEMS microphones stereo record issue with Raspberry Pi 3a+
When record with arecord did you see the VUmeter at the bottom react when using this command:
Can you paste in the output of arecord -l?
Can you post a photo of the wiring to confirm that is all correct.
arecord -D plughw:0 -c2 -r 48000 -f S32_LE -t wav -V stereo -v file_stereo.wav
