TinyUSB, how to write data to CDC serial device from rp2040 host.
ashwidt
Post by ashwidt »
I try to write data to a USB serial device. The host is a RPI pico board, arduino IDE, adafruit TinyUSB USB stack.
If I run the default example device_info.ino, I get the descriptor when I connect the device:
Code from device_info.ino example:
 products from Adafruit!
 MIT license, check LICENSE for more information
 Copyright (c) 2019 Ha Thach for Adafruit Industries
 All text above, and the splash screen below must be included in
 any redistribution
// pio-usb is required for rp2040 host
#include "pio_usb.h"
#define HOST_PIN_DP 0  // Pin used as D+ for host, D- = D+ + 1
#include "Adafruit_TinyUSB.h"
#define LANGUAGE_ID 0x0409  // English
// USB Host object
Adafruit_USBH_Host USBHost;
// holding device descriptor
tusb_desc_device_t desc_device;
// the setup function runs once when you press reset or power the board
  Serial1.begin(115200);
  Serial.begin(115200);
  //while ( !Serial ) delay(10);   // wait for native usb
  Serial.println("TinyUSB Dual Device Info Example");
// core1's setup
void setup1() {
  Serial.println("Core1 setup to run TinyUSB host with pio-usb");
  // Check for CPU frequency, must be multiple of 120Mhz for bit-banging USB
  uint32_t cpu_hz = clock_get_hz(clk_sys);
  if (cpu_hz != 120000000UL && cpu_hz != 240000000UL) {
    while (!Serial) delay(10);  // wait for native usb
    Serial.printf("Error: CPU Clock = %u, PIO USB require CPU clock must be multiple of 120 Mhz\r\n", cpu_hz);
    Serial.printf("Change your CPU Clock to either 120 or 240 Mhz in Menu->CPU Speed \r\n", cpu_hz);
    while (1) delay(1);
  pio_usb_configuration_t pio_cfg = PIO_USB_DEFAULT_CONFIG;
  pio_cfg.pin_dp = HOST_PIN_DP;
  USBHost.configure_pio_usb(1, &pio_cfg);
  // run host stack on controller (rhport) 1
  // Note: For rp2040 pico-pio-usb, calling USBHost.begin() on core1 will have most of the
  // host bit-banging processing works done in core1 to free up core0 for other works
  USBHost.begin(1);
// core1's loop
void loop1() {
  USBHost.task();
// TinyUSB Host callbacks
// Invoked when device is mounted (configured)
void tuh_mount_cb(uint8_t daddr) {
  Serial.printf("Device attached, address = %d\r\n", daddr);
  if (tuh_cdc_mounted(daddr)) {
    Serial.printf("Device is a cdc device!!", daddr);
  } else {
    Serial.printf("Device is NOT cdc DEVICE!!", daddr);
  // Get Device Descriptor
  tuh_descriptor_get_device(daddr, &desc_device, 18, print_device_descriptor, 0);
/// Invoked when device is unmounted (bus reset/unplugged)
void tuh_umount_cb(uint8_t daddr) {
  Serial.printf("Device removed, address = %d\r\n", daddr);
void print_device_descriptor(tuh_xfer_t *xfer) {
  if (XFER_RESULT_SUCCESS != xfer->result) {
    Serial.printf("Failed to get device descriptor\r\n");
    return;
  uint8_t const daddr = xfer->daddr;
  Serial.printf("Device %u: ID %04x:%04x\r\n", daddr, desc_device.idVendor, desc_device.idProduct);
  Serial.printf("Device Descriptor:\r\n");
  Serial.printf("  bLength             %u\r\n", desc_device.bLength);
  Serial.printf("  bDescriptorType     %u\r\n", desc_device.bDescriptorType);
  Serial.printf("  bcdUSB              %04x\r\n", desc_device.bcdUSB);
  Serial.printf("  bDeviceClass        %u\r\n", desc_device.bDeviceClass);
  Serial.printf("  bDeviceSubClass     %u\r\n", desc_device.bDeviceSubClass);
  Serial.printf("  bDeviceProtocol     %u\r\n", desc_device.bDeviceProtocol);
  Serial.printf("  bMaxPacketSize0     %u\r\n", desc_device.bMaxPacketSize0);
  Serial.printf("  idVendor            0x%04x\r\n", desc_device.idVendor);
  Serial.printf("  idProduct           0x%04x\r\n", desc_device.idProduct);
  Serial.printf("  bcdDevice           %04x\r\n", desc_device.bcdDevice);
  // Get String descriptor using Sync API
  uint16_t temp_buf[128];
  Serial.printf("  iManufacturer       %u     ", desc_device.iManufacturer);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_manufacturer_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
    print_utf16(temp_buf, TU_ARRAY_SIZE(temp_buf));
  Serial.printf("\r\n");
  Serial.printf("  iProduct            %u     ", desc_device.iProduct);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_product_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
  Serial.printf("  iSerialNumber       %u     ", desc_device.iSerialNumber);
  if (XFER_RESULT_SUCCESS == tuh_descriptor_get_serial_string_sync(daddr, LANGUAGE_ID, temp_buf, sizeof(temp_buf))) {
  Serial.printf("  bNumConfigurations  %u\r\n", desc_device.bNumConfigurations);
// String Descriptor Helper
static void _convert_utf16le_to_utf8(const uint16_t *utf16, size_t utf16_len, uint8_t *utf8, size_t utf8_len) {
  // TODO: Check for runover.
  (void)utf8_len;
  // Get the UTF-16 length out of the data itself.
  for (size_t i = 0; i < utf16_len; i++) {
    uint16_t chr = utf16[i];
    if (chr < 0x80) {
      *utf8++ = chr & 0xff;
    } else if (chr < 0x800) {
      *utf8++ = (uint8_t)(0xC0 | (chr >> 6 & 0x1F));
      *utf8++ = (uint8_t)(0x80 | (chr >> 0 & 0x3F));
    } else {
      // TODO: Verify surrogate.
      *utf8++ = (uint8_t)(0xE0 | (chr >> 12 & 0x0F));
      *utf8++ = (uint8_t)(0x80 | (chr >> 6 & 0x3F));
    // TODO: Handle UTF-16 code points that take two entries.
// Count how many bytes a utf-16-le encoded string will take in utf-8.
static int _count_utf8_bytes(const uint16_t *buf, size_t len) {
  size_t total_bytes = 0;
  for (size_t i = 0; i < len; i++) {
    uint16_t chr = buf[i];
    if (chr < 0x80) {
      total_bytes += 1;
      total_bytes += 2;
    } else {
      total_bytes += 3;
  return total_bytes;
static void print_utf16(uint16_t *temp_buf, size_t buf_len) {
  size_t utf16_len = ((temp_buf[0] & 0xff) - 2) / sizeof(uint16_t);
  size_t utf8_len = _count_utf8_bytes(temp_buf + 1, utf16_len);
  _convert_utf16le_to_utf8(temp_buf + 1, utf16_len, (uint8_t *)temp_buf, sizeof(uint16_t) * buf_len);
  ((uint8_t *)temp_buf)[utf8_len] = '\0';
  Serial.printf((char *)temp_buf);
Shell output from device_info example:
Device Descriptor:
  bLength             18
  bDescriptorType     1
  bcdUSB              0110
  bDeviceClass        0
  bDeviceSubClass     0
  bDeviceProtocol     0
  bMaxPacketSize0     64
  idVendor            0x067b
  idProduct           0x2303
  bcdDevice           0300
  iManufacturer       1     Prolific Technology Inc.
  iProduct            2     USB-Serial Controller
  iSerialNumber       0
  bNumConfigurations  1
I would expect for the serial_host_bridge.ino example to work,
https://github.com/adafruit/Adafruit_Ti ... bridge.ino
Code from serial_host_bridge example:
 any redistribution
/* This example demonstrates use of Host Serial (CDC). SerialHost (declared below) is
 * an object to manage an CDC peripheral connected to our USB Host connector. This example
 * will forward all characters from Serial to SerialHost and vice versa.
 * Note:
 * - Device run on native usb controller (controller0)
 * - Host run on bit-banging 2 GPIOs with the help of Pico-PIO-USB library (controller1)
 * Requirements:
 * - [Pico-PIO-USB](https://github.com/sekigon-gonnoc/Pico-PIO-USB) library
 * - 2 consecutive GPIOs: D+ is defined by HOST_PIN_DP (gpio20), D- = D+ +1 (gpio21)
 * - Provide VBus (5v) and GND for peripheral
 * - CPU Speed must be either 120 or 240 Mhz. Selected via "Menu -> CPU Speed"
// TinyUSB lib
// Pin D+ for host, D- = D+ + 1
// USB Host object
// CDC Host object
Adafruit_USBH_CDC  SerialHost;
// Setup and Loop on Core0
  Serial.println("TinyUSB Host Serial Echo Example");
void loop()
  uint8_t buf[64];
  // Serial -> SerialHost
  if (Serial.available()) {
    size_t count = Serial.read(buf, sizeof(buf));
    if ( SerialHost && SerialHost.connected() ) {
      SerialHost.write(buf, count);
      SerialHost.flush();
  // SerialHost -> Serial
  if ( SerialHost.connected() && SerialHost.available() ) {
    size_t count = SerialHost.read(buf, sizeof(buf));
    Serial.write(buf, count);
// Setup and Loop on Core1
void setup1() {
  if ( cpu_hz != 120000000UL && cpu_hz != 240000000UL ) {
    while ( !Serial ) {
    while(1) {
      delay(1);
#ifdef HOST_PIN_VBUS_EN
  pinMode(HOST_PIN_VBUS_EN, OUTPUT);
  // power off first
  digitalWrite(HOST_PIN_VBUS_EN, 1-HOST_PIN_VBUS_EN_STATE);
  delay(1);
  // power on
  digitalWrite(HOST_PIN_VBUS_EN, HOST_PIN_VBUS_EN_STATE);
  delay(10);
#endif
  USBHost.begin(1);
void loop1()
  USBHost.task();
  // periodically flush SerialHost if connected
    SerialHost.flush();
// Invoked when a device with CDC interface is mounted
// idx is index of cdc interface in the internal pool.
void tuh_cdc_mount_cb(uint8_t idx) {
  // bind SerialHost object to this interface index
  SerialHost.begin(idx);
  Serial.println("SerialHost is connected to a new CDC device");
// Invoked when a device with CDC interface is unmounted
void tuh_cdc_umount_cb(uint8_t idx) {
  if (idx == SerialHost.getIndex()) {
    // unbind SerialHost if this interface is unmounted
    SerialHost.end();
    Serial.println("SerialHost is disconnected");
But it doesn't detect the device.
I suppose this is because the bDeviceClass is 0 and not 2. ( https://www.usb.org/defined-class-codes )
Does anybody have an idea how to open endpoints and send data to this type of device?
Return to “Other Arduino products from Adafruit”
