LC709203F - OSError
_JonT_
LC709203F - OSError
Post by _JonT_ »
I am using an LC709203F battery gauge with a BQ27074 charger and a pico w. The application requires long-term availability and is meant to be running for days. However, after a few hours the Micropython application quits with an OSError 5. I have tracked this down to the LC709203F. If I disconnect the battery and reconnect it, all is well again. Looking at various forum posts, the issue seems to be that the LC709203F is putting itself to sleep and causing an I2C error to occur when it is accessed. The access function that I have written does actually wake the LC709203F up, but this does not seem to be addressing the issue. While I have seen lots of chatter about this issue, I haven't found anyone who has found a solution. Does anyone have any experience of this using Micropython?
bidrohini
Re: LC709203F - OSError
Post by bidrohini »
Which library did you use?
This one? https://github.com/chris-reichl/MicroPython_LC709203F
_JonT_
Post by _JonT_ »
Yes.
adafruit_support_mike
What sampling interval are you using?
_JonT_
Post by _JonT_ »
adafruit_support_mike wrote: Thu Jan 26, 2023 11:07 pm What sampling interval are you using?
In the test rig I was using I was sampling every 20 seconds.
That would do it.. the auto-sleep time is 1s to 1.5s.
The wakeup time is 400us, or about 40 pulses of the I2C clock. Try doing a dummy read to wake the chip up, then wait 1ms, and take a real reading.
_JonT_
Post by _JonT_ »
Thanks. I will have a try and report back. Did I miss that in the data sheet somewhere?
It's in Table 5 on page 6, toward the bottom of the table:
https://cdn-learn.adafruit.com/assets/a ... 1599248750
It's easy to miss that kind of thing until the becomes specifically relevant.
