I'm installing LEDs on a staircase that has a conductive metal handrail. The goal is to have the LED strips turn on sequentially based on the direction the stairs are used. I want to ditch the usual motion sensors and use the railing as a capacitive input.
Are there any sensors in the world when, if connected to the top and bottom of the railing, would be able to detect relative differences between the two sensors in the electrical properties of the handrail? On one hand, the railing is one solid piece of conducting metal. On the other, I expect some kind of sensor at the top would see a relative difference in something relative to the one at the bottom that has to go through more distance to "feel" the same input. Thoughts? Possible in some way?
Quantitative Capacitive Touch in Same Circuit
- mikeysklar
Re: Quantitative Capacitive Touch in Same Circuit
I think I remember discussing the LED part of this project with you before.
I like the metal hand rail directional concept. It should be really easy to detect which direction. If you use an ADC pin on your controller and connect one side of the railing to the ADC input and the other to GND you should be able to tell based on the ADC value (really high or really low) which direction someone has touch the railing on.
I'm saying you do not need an additional sensor. The metal railing will be doing that for you when you connect it to an analog pin.
- jd1
Wasn't me. I just got the railing! But, please forgive me, as I'm a total newbie and need to read a ton to learn how to do this right, now that I have a point in the right direction, but here's my follow up: if I have an input at the top and ground at the bottom, that suggests there's a live voltage running through the railing, right? Any risk to that? Again, apologies for the newbish question.
- jd1
Sorry one additional question. I need three states for this setup: one for each end and a third when no one is touching the railing at all. When looking at ADC pins, it looks like they always output either a high or low. How do I achieve the third state?
- mikeysklar
@jd1,
This page shows how to wire up and code analog inputs. It is about 4 lines of code to get going with CircuitPython.
https://learn.adafruit.com/circuitpytho ... ter-inputs
The voltage and current will be very low so not risk to touch (3.3v and maybe a few mA of current).
The different states will need to be determined through some trial and error. Readings with nobody touching, when someone is at the top versus at the bottom. You have to wire it up which will determine which direction will be high vs low.
