Raspberry DC and Stepper Motor Hat
laurenzBMR5
Post by laurenzBMR5 »
Hello, I installed the Adafruit-Motor-HAT-Python-Library and i started the DCTest.py with
python DCTest.py
and everything worked fine. However for another project i have to get it working on python3 and when i try
python3 DCTest.py
i get this error
ImportError: No module named 'Adafruit_PureIO
I try installing Adafruit Pure IO with
sudo pip3 install Adafruit-PureIO
and i get this error:
distutils.errors.DistutilsError: Could not find suitable distribution for Requirement.parse('setuptools_scm')
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-3viech6e/Adafruit-PureIO/
I'd be very thankful for any help :)
bidrohini
Re: Raspberry DC and Stepper Motor Hat
Post by bidrohini »
I recommend to update the setup tools.
pip install --upgrade setuptools
laurenzBMR5
It seems to be up to date:
Requirement already up-to-date: setuptools in /usr/local/lib/python2.7/dist-packages (44.1.1)
adafruit_support_carter
That library is deprecated:
https://github.com/adafruit/Adafruit-Mo ... on-Library
Please see guide for current setup and Python usage:
https://learn.adafruit.com/adafruit-dc- ... spberry-pi
