MatrixPortal M4 and Simpletest
guicide
Post by guicide »
I soldered 8 and E together on my MatrixPortal M4. I connected the M4 to a 64x64 RGB LED Matrix Panel - 2mm Pitch[ID:5362] both were purchased from adafruit in January of 2023. I get lots of diagonal, flickering red lines no matter which CircuitPython examples I have tried. So, after reading the forums, I tried "matrix_portal_simpletest_64x64.UF2". The resulting screen looks like: Image. Does anyone know if this is a Success or Failure?
MOD EDIT: adding linked image inline:
dastels
Re: MatrixPortal M4 and Simpletest
Post by dastels »
The image link appears broken.
guicide
Post by guicide »
I tried a few times to get the image to appear in the post. It did not originally, but it does when I look at the post now. It shows three red diagonal stripes about 5 pixels wide at about a 30 degree slope.
dastels
Post by dastels »
That doesn't sound right. Where did you find that UF2?
guicide
Post by guicide »
dastels
Post by dastels »
You copied it to MATRIXBOOT?
Double check the E-8 jumping.
The connector is lined up and inserted correctly into the connector on the LED matrix?
guicide
Post by guicide »
Yes, I copied it to MatrixBoot. Double pressed the reset button. I'm certain of the E-8 solder. pin 16 also shows no continuity with 8. I've connected/disconnected many times. Tried an external power supply. I've seen some suggestions that an FM6126A might have issues, my M4 has FM6124D which I see no mention of. I've ordered a 32x32, to test the M4 further.
dastels
Post by dastels »
The MatrixPortal works otherwise? I.e. things that don't use the matrix?
I'll see about getting some other eyes on this.
adafruit_support_carter
Please post another photo showing the backside of the setup with the MatrixPortal attached to the RGB matrix.
guicide
Post by guicide »
FYI - The NEOPixel is sometines white.
MOD EDIT - adding image inline:
back of 5362.jpg (781.04 KiB) Viewed 122 times
dastels
Post by dastels »
Huh. The image link is showing broken for me, but if I inspect it I can open it.
The power connections to the matrix are missing.
https://learn.adafruit.com/adafruit-mat ... trixportal
Were those connected previously when you tested with the UF2?
guicide
Post by guicide »
Yes. I disconnected them to take the photo.
guicide
Post by guicide »
dastels wrote: Tue Jan 17, 2023 12:53 pm Huh. The image link is showing broken for me, but if I inspect it I can open it.
I now see two copies of my image in the post.
Your img tag link usage does not work on our end:
[img]http://guicide.com/adafruit/back%20of%205362.png[/img]
Adding the image as an attachment to the post is the preferred method.
Or just provide the link as plain text, ex:
