Hi, I have a project using a 3v Itsby Bitsy and all is good (GREAT board). I've cut the trace on the battery output line, and that works perfectly with the on/off switch. However, when I plug in the USB cable for charging, the ItsyBitsy powers up. Is this the right behavior, and how do I prevent the board from running when charging the battery?
Phil
Itsybitsy 3v with Backpack Add-On
- dastels
Re: Itsybitsy 3v with Backpack Add-On
You can't. Connecting USB will power the ItsyBitsy as well as charge the battery.
- philmonty
Thanks, and what I thought. I'll look for another workaround :-)
