I recently updated my bootloader for my ItsyBitsy M4 using the flash drive method described on the Adafruit support page. It is now at:
UF2 Bootloader v3.14.0 SFHWRO
Model: ItsyBitsy M4 Express
Board-ID: SAMD51G19A-Itsy-v0
The problem I have now is that every time I try to upload a sketch, the sketch does not upload and it goes into bootloader mode (green neopixel with pulsing red light) and flash drive window appears ? At the same time it seems to switch the com port which explains why the sketch does upload. What gives?
Thanks in advance.
Mark
Trouble with Itsy Bitsy M4 bootloader
- adafruit_support_carter
Re: Trouble with Itsy Bitsy M4 bootloader
Are you seeing that same behavior even uploading a basic Blink example sketch?
- mbiasotti
Yes, same behavior on Blink sketch (first thing I tried). I've had it go into this behavior about a month ago and can't remember how I got out of it (i.e. single, multiple reset button clickes etc.) All along I've been using the 1.9 version of Arduino IDE, not on 2.0 yet.
- mbiasotti
Thanks, I'll have a look and let you know. Currently I'm traveling so won't get back to this til saturday.
Mark
Mark
- mbiasotti
I just tried the blink and the sketch I'm working on using my 2.0 Arduino and it uploads fine. When I get home to my 1.9 version I'll try again, if not I just start using Arduino IDE 2.0 on on a full-time basis - might as well.
thanks for your help.
Mark
Mark
