DC Motor Control throttle not working
Play with it! Please tell us which board you're using.
knasman
Post by knasman »
I have a CPX and I've hooked it up to a DRV8833 motor controller and setting throttle = 0 isn't stopping the motor. Here's the relevant code snippet. It doesn't matter if I set the throttle to .5, .1, or .01 the motor spins full speed. What should I check on?
Keith
# Create motors
PWM_A2 = board.A2
PWM_A3 = board.A3
PWM_FREQ = 25
DECAY_MODE = motor.SLOW_DECAY
positive_pwm1 = pwmio.PWMOut(PWM_A2, frequency=PWM_FREQ)
negative_pwm1 = pwmio.PWMOut(PWM_A3, frequency=PWM_FREQ)
motor_right = motor.DCMotor(positive_pwm1, negative_pwm1)
motor_right.decay_mode = DECAY_MODE
def move_fwd(duration):
    """ Move forward for duration amount of time. """
    print()
    motor_right.throttle = .5
    print("Forward for %s seconds" % duration)
    pixel_control([0, 9], GREEN, 'on')
    time.sleep(duration)
    print()
    pixel_control([0, 9], GREEN, 'off')
    motor_right.throttle = 0
while True:
        move_fwd(.5)
        time.sleep(10)
dastels
Re: DC Motor Control throttle not working
Post by dastels »
Double check your wiring, both logically (are the connections correct) and physically (are the connections good without shorts.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
