Specifically the EPS32-S2 with the pressure sensor (Product ID: 5303). The easiest way to see the problem is probably with the code below. Serial1 has no problems, and returns 128. SerialPort2 returns 0.
I'm talking with two sensors and I've worked my way down to this. Serial1 and Tx, Rx work fine with both sensors. I cannot get the third serial port to work regardless of what pins I try, and I've searched everywhere for anyone having similar problems. Thank you for your help.
--------------Code below-----------------
HardwareSerial SerialPort2(2);
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Starting...");
Serial1.begin(9600);
SerialPort2.begin(9600,SERIAL_8N1,13,12);
Serial.println(Serial1.availableForWrite());
delay(200);
Serial.println(SerialPort2.availableForWrite());
delay(200);
Cannot get third serial port to work on EPS32-S2
- ddodd
- bidrohini
Re: Cannot get third serial port to work on EPS32-S2
Have you tried writing serial2 instead of SerialPort2?
https://icircuit.net/arduino-esp32-hard ... ample/3181
- ddodd
Thanks, but that doesn't make any difference. I saw that example before and it's doesn't declare HardwareSerial serial2(2) at the beginning.
- ddodd
When I add that declaration, your example runs, but doesn't give the expected output. The text is displayed only the first time, suggesting the same problem, that serial2 is not working. I just tried a different board, with the same results. Could it be something in my Arduino IDE settings? I have no idea what to try. Thank you.
- ddodd
When I run that example, slightly modified, as shown below it's telling me neither serial port is available (reports not available for both). IDE 2.0 didn't make a difference. I don't know what else to try, if you can give some suggestions. Thanks for your help.
HardwareSerial Serial2(2);
#define RXD2 13
#define TXD2 12
Serial.begin(9600);
while (!Serial) {
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
delay(1000);
Serial.println("Loopback program started");
if(Serial.available()){
Serial.print("-");
Serial2.print(Serial.read());
else{Serial.println("Serial not available");}
if(Serial2.available()){
Serial.print(".");
Serial.print(Serial2.read());
else{Serial.println("Serial2 not available");}
delay(200);
#define RXD2 13
#define TXD2 12
Serial.begin(9600);
while (!Serial) {
delay(1000);
Serial.print("-");
Serial.print(".");
delay(200);
- ddodd
That's not 100% right. Serial is available if I type something in. The serial monitor repeats the '-', suggesting serial is fine. I just can't get Serial2 to respond. I have 12 and 13 wired together, per the example, and that's the only connections on the board.
- ddodd
Looks like SoftwareSerial.h is working
