pi cam 3
- xdased14
pi cam 3
order #2997720-4329440857 just received this pi cam 3 was going to use it as a replacement for a cam v2 on a pi4 got no signal or signs of life, update pi to lastest, added libcam stuff tried again on 2 pi 3 b+ and another pi4, tried with ribbon cable that came with it as well as 3 other known to work ribbon cables. when through toggling cam in raspi-config. all pi's show cam supported=1 detected=0 when doing vcgencmd get_camera in terminal
- PXL_20230119_025801468.jpg (111.21 KiB) Viewed 91 times
- PXL_20230119_025620932.jpg (77.63 KiB) Viewed 91 times
- PXL_20230119_025616686.jpg (75.69 KiB) Viewed 91 times
- bidrohini
Re: pi cam 3
You can check this out: https://forums.raspberrypi.com/viewtopic.php?t=197575
- xdased14
Re: pi cam 3
I can try it but that posters problem was with dual cams I'm just wanting to go from cam v2 to v3 wide. Replaced all ribbon cables as well as bought another v2 and even installed that v2 on another pi. V2s all work still no x3 wide detection
- xdased14
Re: pi cam 3
still no go on getting the pi cam v3 wide to be detected or show video or stills, tried every board i have(not the 2 new pi zero wh i just picked up) every ribbon cable i have including the ones that came with the cam v3 and the new v2 i just picked up . I did notice that the lens/module rattles like something is loose(cam was delivered in a adafruit bubble mailer). i just want a working v3 wide seeing as it cost me $50+ for it. i can get the v2's to work fine so i believe it has to be the cam module and i would like it replaced
- xdased14
Re: pi cam 3
so I am i to assume that i just have to take the lost on a pi v3 cam wide that was defective out of the box as i have not heard anything from adafruit on the matter other than saying i had to post here first, i can always try a charge back from the cc company
Re: pi cam 3
Sorry to have missed this one on your first post.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
