I need a very bright RGB LED matrix. Which RGB LED Matrix has the highest cd/m^2 ?
Is the 32x32 4mm pitch the brightest?
https://www.adafruit.com/product/607
Or 64x64 2.4mm pitch
https://www.adafruit.com/product/3649
The datasheets don't specify cd/m^2 for all of them
Which RGB LED Matrix has the highest cd/m^2?
- wiliamho
- mikeysklar
- wiliamho
Re: Which RGB LED Matrix has the highest cd/m^2?
Do you know much power 64x64 3 mm needs?
Do I need to buy the 5V 10A power supply or 5V 4A power supply?
- mikeysklar
8A would be recommended for this 64x64.
https://learn.adafruit.com/rgb-led-matr ... ple-panelsNext, you'll need to power all your panels. Each panel has a 4-pin power connector, and most of Adafruit's panels include a Y-splitter power cable which can be connected to 2 panels. The power supply current requirement increases according to the number of panels, but the voltage requirement is always 5V. Remember that we recommend a 5V 4A supply for a single 64x32 pixel panel, so our recommendation becomes 4×2=8A for 2 panels and 4×4=16A for 4 panels. By using dimmer colors and avoiding big solid areas on the display, you may be able to get by with a smaller power supply.
