I installed the blinka stuff and tried to run blinkatest.py. Is crashes at the first line (import board) because board cannot be found. When I run the test as `sudo python blinkatest.py` it works correctly. The same when I disable anaconda initialization in my .bashrc script and run as `python blinkatest.py`. So I figure the library scripts are not installed in the environment libraries but in some global library. Is this the expected behavior? If so, is there a workaround for using adafruit products without blinka?
I have a raspberry 4 with the latest 64-bit version of raspberry os and the latest version of anaconda (22.9.0) for arm. I use environments because quite some projects have conflicting demands.
Blinka appears not to cooperate with (conda) env
- nocom
- mikeysklar
Re: Blinka appears not to cooperate with (conda) env
Are you running the Anaconda distribution?
https://learn.adafruit.com/circuitpytho ... spberry-piAt this time, Blinka requires Python version 3.7 or later, which means you will need to at least be running Raspberry Pi OS Bullseye.
