I'm thinking of buying 7 of these: https://www.adafruit.com/product/4732
1) What would I need to connect them together?
2) Would they work in "extended" mode and not in a mirror mode?
3) Could one raspberry pi control all 7?
4) Actually buying 6 of those is enough if I add one of these to them: https://www.adafruit.com/product/2279 and the question is: Is it easy to change the orientation of the last panel to be 64 pixels high and 32 pixels wide? Is this something I would have to do in code or is there an easier way?
5) What is the list of all parts I would need to order to connect all displays together and to the raspberry pi (which I already have)?
Thank you in advance!
Chaining matrixes and necessary parts
- SaturdayMorning
- mikeysklar
Re: Chaining matrixes and necessary parts
You can use the RGB Matrix Bonnet.
https://www.adafruit.com/product/3211
A 16A power supply will get you four panels. There be dragons going bigger than that, but a Pi can drive more it has the necessary memory and processor ability.
https://learn.adafruit.com/rgb-led-matr ... ple-panels
- SaturdayMorning
So would the matrix bonnet and the panels be enough?
I don't need any more parts to be able to connect them to the PI?
Also what about this:
- mikeysklar
No, you will need a significant power supply > 16A for 4 panels.
Six panels is complicated since we have no documentation showing usage over 4 panels. You also fall into the realm of needing a larger than 20A power supply. While it may be possible it is definitely not worth it if you can make things work with 4 panels.
Adjusting resolution for the last panel in theory looks easy, but I can't point to working examples so again avoid this and stick with symmetric matching panel resolution to ensure your success.
- SaturdayMorning
My project is to make a led display that's the same width as a regular piano and 64 pixels high. Since the leds will not match the keys exactly it would have to be like 3-5 leds per key.mikeysklar wrote: ↑Fri Jan 20, 2023 5:09 pm No, you will need a significant power supply > 16A for 4 panels.
A regular piano is like 122.5 cm wide and contains 88 keys.
Do you have any suggestions for me how to do this?
- mikeysklar
I would consider the 5mm and 6mm RGB Matrix panels 64x32 for your project. They are physically larger so you match the sizing requirements of a normal piano and only require 4 or less panels.
; Dimensions: 318mm x 158mm x 15mm / 12.5” x 6.2” x 0.6”
https://www.adafruit.com/product/2277
; Dimensions: 385mm x 190mm x 13mm / 15.2” x 7.5” x 0.5”
https://www.adafruit.com/product/2276
