Using 4 Dual Alphanumeric Display(1907)
Hexter48044
Post by Hexter48044 »
I am designing a project requiring multiple 8 character alphanumeric displays and need to reduce component count as well as PCB real estate.
Will the Adafruit_LED_Backpack_Library-1.3.2 support 4 dual alphanumeric LED displays(ID 1907) connected to the Adafruit HT16k33 backpack(ID 1427) as shown in the supplied schematic?
Sample code extract as follows:
alpha4.writeDigitAscii(0, displaybuffer[0]);
alpha4.writeDigitAscii(1, displaybuffer[1]);
alpha4.writeDigitAscii(2, displaybuffer[2]);
alpha4.writeDigitAscii(3, displaybuffer[3]);
alpha4.writeDigitAscii(4, displaybuffer[4]);
alpha4.writeDigitAscii(5, displaybuffer[5]);
alpha4.writeDigitAscii(6, displaybuffer[6]);
alpha4.writeDigitAscii(7, displaybuffer[7]);
adafruit_support_carter
Re: Using 4 Dual Alphanumeric Display(1907)
It can do two modules. You can see an example of this being done in this product:
https://www.adafruit.com/product/1912
Schematics are available here:
https://learn.adafruit.com/adafruit-led ... /downloads
That leaves several COM pins unused. So it seems possible. By extending this to two more modules using those pins.
Hexter48044
Thank you for your quick response.
Yes I am aware that it can be done with 2 modules as I have accomplished with other projects. However, using 2 modules increases component costs and takes up more space on my PCB, which I have to keep at a minimum.
