Adafruit SHARP Memory Display - Screen Orientation
jonnydub
Post by jonnydub »
I'm a noob so please bear with me!
Recently brought a Adafruit SHARP Memory Display Breakout - 1.3" 168x144 which a really nice display however i'm having trouble finding the code to change the screen display from Portrait (144x168) to Landscape (168x144) as I wish to utilise the display side on.
Is there a method to change this setting using the display driver or will I need to rotate everything I draw 90 degrees (e.g images and text)
# display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 96, 96)
display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168)
Any help much appreciated
Jonny
mikeysklar
Re: Adafruit SHARP Memory Display - Screen Orientation
Post by mikeysklar »
Jonny,
Try adding:
display.setRotation(1);
It can go right after:
display.clearDisplay();
https://github.com/adafruit/Adafruit_SH ... emtest.ino
jonnydub
Post by jonnydub »
Thank you @mikeysklar
I was using Python via a Pi4 but thanks for that link, i'll use this code instead.
