Hello
I'm using the proposes file "temp_humidity.py". I runs okay (no overrun in data, only 17 values / sec).
After abbout 1 hour the following error occurs
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x75639910>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url:
/api/v2/kanaren56/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x75639910>:
Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "temp_humidity.py", line 61, in <module>
aio.send(temperature_feed.key, str(temperature))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 167, in send_data
return self.create_data(feed, payload)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 313, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 137, in _post
data=json.dumps(data))
File "/usr/lib/python3/dist-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443):
Max retries exceeded with url: /api/v2/kanaren56/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x75639910>:
Any idea what goes wrong ?
Thanks for your help ....
Temperatur and humdity logger with raspi
- bidrohini
Re: Temperatur and humdity logger with raspi
You may check this thread. Maybe it will help: https://forums.raspberrypi.com/viewtopic.php?t=199037
- kanaren56
Thanks, I‘ll test is a.s.a.p
- kanaren56
I looked through the explanation but I haven’t configured the Raspberry beeing a DNS server.(Service is not Running).
So the problem of the Python script seems not to be linked to the DNS server.
