Hello
i recently made a custom stepsequencer 16 with 4 Trellis Leds/Buttons PAD
The code is based on UNTZtrument : Trellis MIDI Instrument.
In that code we have a rotary encoder to set tempo
And i wish know how to set the Variable Tempo with USB MIDI Clock (ableton Tempo) to synchronize the stepsequencer with ableton or an other DAW
Any way to begin will be apprecieted to do that
// Simple UNTZtrument MIDI step sequencer.
// Requires an Arduino Leonardo w/TeeOnArdu config (or a PJRC Teensy),
// software on host computer for synth or to route to other devices.
#include <Wire.h>
#include <Adafruit_Trellis.h>
#include <Adafruit_UNTZtrument.h>
#include "MIDIUSB.h"
#define LED 13 // Pin for heartbeat LED (shows code is working)
#ifndef HELLA
// A standard UNTZtrument has four Trellises in a 2x2 arrangement
// (8x8 buttons total). addr[] is the I2C address of the upper left,
// upper right, lower left and lower right matrices, respectively,
// assuming an upright orientation, i.e. labels on board are in the
// normal reading direction.
Adafruit_Trellis T[4];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73 };
#else
// A HELLA UNTZtrument has eight Trellis boards...
Adafruit_Trellis T[8];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3],
&T[4], &T[5], &T[6], &T[7]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73,
0x74, 0x75, 0x76, 0x77 };
#endif // HELLA
#define WIDTH ((sizeof(T) / sizeof(T[0])) * 2)
#define N_BUTTONS ((sizeof(T) / sizeof(T[0])) * 16)
// Encoder on pins 4,5 sets tempo. Optional, not present in
// standard UNTZtrument, but won't affect things if unconnected.
enc e(4, 5);
uint8_t grid[WIDTH]; // Sequencer state
uint8_t heart = 0, // Heartbeat LED counter
col = WIDTH-1; // Current column
unsigned int bpm = 240; // Tempo
unsigned long beatInterval = 60000L / bpm, // ms/beat
prevBeatTime = 0L, // Column step timer
prevReadTime = 0L; // Keypad polling timer
// The note[] and channel[] tables are the MIDI note and channel numbers
// for to each row (top to bottom); they're specific to this application.
// bitmask[] is for efficient reading/writing bits to the grid[] array.
static const uint8_t PROGMEM
note[8] = { 72, 71, 69, 67, 65, 64, 62, 60 },
channel[8] = { 1, 1, 1, 1, 1, 1, 1, 1 },
bitmask[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
pinMode(LED, OUTPUT);
#ifndef HELLA
untztrument.begin(addr[0], addr[1], addr[2], addr[3]);
#else
untztrument.begin(addr[0], addr[1], addr[2], addr[3],
addr[4], addr[5], addr[6], addr[7]);
#endif // HELLA
// Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
// 400 KHz. We can force this for faster read & refresh, but may
// break compatibility with other I2C devices...so be prepared to
// comment this out, or save & restore value as needed.
#ifdef ARDUINO_ARCH_SAMD
Wire.setClock(400000L);
#endif
#ifdef __AVR__
TWBR = 12; // 400 KHz I2C on 16 MHz AVR
#endif
untztrument.clear();
untztrument.writeDisplay();
memset(grid, 0, sizeof(grid));
enc::begin(); // Initialize all encoder pins
e.setBounds(60 * 4, 480 * 4 + 3); // Set tempo limits
e.setValue(bpm * 4); // *4's for encoder detents
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
MidiUSB.flush();
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
MidiUSB.flush();
// Turn on (or off) one column of the display
void line(uint8_t x, boolean set) {
for(uint8_t mask=1, y=0; y<8; y++, mask <<= 1) {
uint8_t i = untztrument.xy2i(x, y);
if(set || (grid[x] & mask)) untztrument.setLED(i);
else untztrument.clrLED(i);
uint8_t mask;
boolean refresh = false;
unsigned long t = millis();
enc::poll(); // Read encoder(s)
if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
if(untztrument.readSwitches()) { // Button state change?
for(uint8_t i=0; i<N_BUTTONS; i++) { // For each button...
uint8_t x, y;
untztrument.i2xy(i, &x, &y);
mask = pgm_read_byte(&bitmask[y]);
if(untztrument.justPressed(i)) {
if(grid[x] & mask) { // Already set? Turn off...
grid[x] &= ~mask;
noteOff(pgm_read_byte(&channel[y]), pgm_read_byte(¬e[y]), 127);
} else { // Turn on
grid[x] |= mask;
refresh = true;
prevReadTime = t;
digitalWrite(LED, ++heart & 32); // Blink = alive
if((t - prevBeatTime) >= beatInterval) { // Next beat?
// Turn off old column
line(col, false);
for(uint8_t row=0, mask=1; row<8; row++, mask <<= 1) {
if(grid[col] & mask) {
noteOff(pgm_read_byte(&channel[row]), pgm_read_byte(¬e[row]), 127);
// Advance column counter, wrap around
if(++col >= WIDTH) col = 0;
// Turn on new column
line(col, true);
noteOn(pgm_read_byte(&channel[row]), pgm_read_byte(¬e[row]), 127);
prevBeatTime = t;
refresh = true;
bpm = e.getValue() / 4; // Div for encoder detents
beatInterval = 60000L / bpm;
if(refresh) untztrument.writeDisplay()
How to sync step sequencer (UNTZtrument Trellis 4x4 Adafruit) with tempo of Ableton live?
- Raptures
- Matmartigan
