I have used the video looper on 5 raspberry pi's and for all of them it works. Now I'm setting this up on the 6th one and its not working. After i have run the command "sudo ./install.sh" the omxplayer starts. When I restarting the pi it's not starting again. I have tried with one of the other's sd cards and it works fine. I have also reinstalled the pi and done the process once more but the same problem. I have even tried with another sd card but that's the same problem.
When I try to run the command "python3 -u -m Adafruit_Video_Looper.video_looper" The screen turns black and then goes back to the desktop. The terminal say's "AttributeError: module "pyudev" has no attribute 'Context'"
Raspberry pi video looper
- mikeysklar
Re: Raspberry pi video looper
Does the problematic SD card work with one of the five working Pi’s?
