QT PY ESP32 Pico not recognized by Whippersnapper
- robertr729
I have flashed the firmware for my QT PY ESP32 Pico successfully and the IO Whippersnapper interface does not recognize my board. I've tried other cables to no avail. I have a yellow/green light on the board after the download. I'm running on an MAC. I've downloaded the drivers too.
- bidrohini
Re: QT PY ESP32 Pico not recognized by Whippersnapper
Try this troubleshooting guideline: https://learn.adafruit.com/adafruit-qt- ... pper-setup
Is your QT PY working otherwise? Can you upload codes to it using the Arduino IDE?
- brubell
- Learn User Page
First, double-check the adafruit io username and key in the secrets.json file on your WIPPER drive. Then, double-check the wifi ssid and password in the secrets.json file on your WIPPER drive.robertr729 wrote: ↑Sun Jan 22, 2023 6:25 pm I have flashed the firmware for my QT PY ESP32 Pico successfully and the IO Whippersnapper interface does not recognize my board. I've tried other cables to no avail. I have a yellow/green light on the board after the download. I'm running on an MAC. I've downloaded the drivers too.
If the values within the secrets.json file look correct, let me know and I can help you with next steps.
