Ov7670 and raspberry pi pico
Saj555
Post by Saj555 »
I try to capture and save a small photo with ov7670 camera module and save it to raspberry pi PICO internal memory as a BMP file format using circuitpython liberaries. any solution or sample code?
first, i tried to view color bars test pattern in this way:
captured image with ov7670 into raspberry pi pico internal memory
Asked today
Modified today
Viewed 5 times
import time
import board
import busio
import digitalio
import storage
from adafruit_bitmapsaver import save_pixels
from ulab import numpy as np
from displayio import (
    Bitmap,
    Group,
    TileGrid,
    Palette,
    ColorConverter,
    Colorspace,
from adafruit_ov7670 import (
    OV7670,
    OV7670_SIZE_DIV8,
    OV7670_SIZE_DIV16,
    OV7670_COLOR_RGB,
    OV7670_COLOR_YUV,
    OV7670_TEST_PATTERN_COLOR_BAR
with digitalio.DigitalInOut(board.GP10) as reset:
    reset.switch_to_output(False)
    time.sleep(0.001)
    bus = busio.I2C(board.GP1, board.GP0)
cam = OV7670(
    bus,
    data_pins=[
        board.GP12,
        board.GP13,
        board.GP14,
        board.GP15,
        board.GP16,
        board.GP17,
        board.GP18,
        board.GP19,
    clock=board.GP11,
    vsync=board.GP7,
    href=board.GP21,
    mclk=board.GP20,
    shutdown=None,
    reset=board.GP10,
cam.size = OV7670_SIZE_DIV8
cam.colorspace = OV7670_COLOR_RGB
cam.test_pattern = OV7670_TEST_PATTERN_COLOR_BAR
bitmap = Bitmap(cam.width,cam.height, 65535)
arr = np.zeros((2*cam.width, 2*cam.height), dtype=np.uint16)
cam.capture(arr)
palette=Palette(cam.width*cam.height)
for y in range(cam.height):
    for x in range(cam.width):
        palette[y*cam.width+x]=arr[x,y]
x=0
y=0
         bitmap[x,y]=y*cam.width+x
save_pixels('/test.bmp', bitmap, palette)
print("done")
But the result is the attached file
what s the problem? how can i get a clear image?
Code result
Code result
Last edited by adafruit_support_carter on Mon Jan 30, 2023 3:27 pm, edited 1 time in total.
bidrohini
Re: Ov7670 and raspberry pi pico
Post by bidrohini »
You can cross-check your wiring and settings with this one: https://ashishware.com/2022/09/03/pipic ... ification/
Saj555
Post by Saj555 »
thanks for your reply
as the output format of ov7670 is in RGB565 and windows bitmap format is in RGB888, i used this approach for conversion:
def RGB(pixel):
    R5=pixel >> 11
    G6=(pixel & 0b11111100000) >> 5
    B5= pixel & 0b11111
    R8 = round(255/31 * R5)
    G8 = round(255/63 * G6)
    B8 = round(255/31 * B5)
    return (R8,G8,B8)
for y in range(0,cam.height):
    for x in range(0,cam.width):
        palette[y*cam.width+x] =RGB(arr[x,y])
x=0
y=0
save_pixels('/test3.bmp', bitmap, palette )
so the result was better now i m wondering why the vertical bars appear
