Hello, I tried to get a display SSD1306 or SH1106 to work on an RP2040 using CircuitPython 8.
I always get this:
>>> from adafruit_display_text import label
File "<stdin>", line 1, in <module>
ImportError: no module named 'adafruit_display_text'
I tried to set it up with ...-raspberry_pi_pico-en_US-8.0.0-beta.6.uf2 and ...-raspberry_pi_pico-en_US-7.3.3.uf2.
Now I even do not have any hardware connected. From my knowledge after putting the four files of the adafruit_display_text library in the lib folder (either .mpy or .py) on the Pico I restarted the controller and tried
"from adafruit_display_text import label"
on the REPL of thonny. I always got the same error.
I did a search on this and got some hints on taking the right library and safely ejecting the Pico but nothing worked for me.
This should be one of the most commonly used libraries.
Any suggestions on what I might have done wrong?
- Dorky
- dastels
Re: ImportError: no module named 'adafruit_display_text'
You need to put the adafruit_display_text folder into CIRCUITPY/lib, not the files it contains.
- Dorky
Thanks a lot.
With all that good documentation and adafruit learning and so on I must be stupid to not having noticed that.
I guess I was not the first one though.
Dirk
Dirk
- blakebr
D,
No need to apologize unless you are the reason Comet cleanser has the warning do not eat.
Bruce
Bruce
