I am beginning a project to make a climate sensor that will measure climate (temperature and humidity) from the ground to the top of a tree as the sensor is pulled up a rope. I was thinking of using the Adafruit DPS310 Precision Barometric Pressure / Altitude Sensor - STEMMA QT / Qwiic to determine the height of the sensor.
I am planning to use the sensor in wet environments. I saw that there were water resistant pressure sensors, and was wondering if there could also be a water resistant version of the precision pressure sensor.
Lydia
water proof precision barometric pressure
- sj_remington
Re: water proof precision barometric pressure
Electronic circuitry intended for use in damp outdoor environments must be very carefully protected from dampness and even condensation caused by temperature changes. PCBs must be either "conformally coated" or the entire circuit "potted" in waterproof silicon compound.
Otherwise corrosion due to electrolysis will quickly set in, sometimes in just a few days, and destroy the boards.
Modules intended for hobby use are usually not so protected, so search for sensors intended for the sort of application you have in mind.
