ItsyBitsy M4 Trigger Bootloader Mode via USB
Post Reply
User91827
Post by User91827 »
I would like to be able to trigger the bootloader mode from the USB connection. I see this happen when an Arduino sketch is loaded, so I think it is possible. I am looking to be able to do this on demand so that I can update the code via a remote system.
My setup is a Raspberry Pi which I can access via SSH connected to the ItsyBitsy M4 via USB. Usually I leverage the USB CDC Serial connection, but occasionally would like to be able to update the software on the ItsyBitsy without needing to connect it to my main computer.
I am not asking for a comprehensive solution, as I think I have the other pieces sorted out. Just looking to be able to switch to bootloader mode without needing to physically hit the reset button.
adafruit_support_mike
Re: ItsyBitsy M4 Trigger Bootloader Mode via USB
On the computer side, open a 1200-baud Serial connection then close it. That's the signal the Arduino IDE uses to trigger a reboot when uploading new firmware.
Post Reply
Return to “Itsy Bitsy 32u4, M0, M4”
