Hello - I understand how to change the USB drive name using the storage and remount in boot.py.
However, I'd like to change it in the CP source and recompile? If possible, in which CP source file would I need to change?
Thank you -
Change name of CIRCUITPY Drive
- neradoc
Re: Change name of CIRCUITPY Drive
You can define CIRCUITPY_DRIVE_LABEL in a board's mpconfigboard.h, see for example:
https://github.com/adafruit/circuitpyth ... oard.h#L16
It will only change when the drive if formatted from Circuitpython (on first install from a unformatted flash or using storage.erase_filesystem()).
Note that you can also change the name from the host computer side.
- puttley
Perfect -- thanks so much.
- tannewt
The name is the file system label and you can set it at runtime. CircuitPython only sets it when creating the filesystem. I've done it from boot.py with:
import storage
storage.remount("/", readonly=False)
storage.getmount("/").label = "FEATHER"
storage.remount("/", readonly=True)
