NodeMCU ESP8266_PIR stays HIGH
QnBarb
Post by QnBarb »
Does anyone know why the NodeMCU ESP8266 board is sending PIR sensor data as 'HIGH' even though the sensor is not connected. Therefore, it's sending false data to Adafruit IO.
Thanks in advance.
Just in case, here is the code I used:
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
const char *ssid = "****"; // Enter your WiFi Name
const char *pass = "****"; // Enter your WiFi Password
WiFiClient client;
#define MQTT_SERV "io.adafruit.com"
#define MQTT_PORT 1883
#define MQTT_NAME "****" // Your Adafruit IO Username
#define MQTT_PASS "****" // Adafruit IO AIO key
const int ledPin = D0;
const int sensor = D2;
const int buzzer = D6; // Here we are defining the pins which we will use to connect our sensors, LED and Buzzer
//Set up the feed you're publishing to
Adafruit_MQTT_Client mqtt(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
Adafruit_MQTT_Publish pirsensor = Adafruit_MQTT_Publish(&mqtt,MQTT_NAME "/f/pirsensor"); // pirsensor is the Adafruit IO feed name where you will publish your data
Adafruit_MQTT_Subscribe LED = Adafruit_MQTT_Subscribe(&mqtt, MQTT_NAME "/f/LED"); //Set up the feed you're subscribing to from Adafruit IO
void setup()
Serial.begin(115200);
delay(10);
mqtt.subscribe(&LED); //To start the communication between the NodeMCU and Adafruit IO
pinMode(buzzer, OUTPUT);
pinMode(ledPin, OUTPUT); // The declaration of PinMode of the NodeMCu
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass); // Here the NodeMCU ESP8266 will try to connect to the wifi with the ID and Password you have provided
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print("."); // this piece will print "....." till not connected
Serial.println("");
Serial.println("WiFi connected"); // this will be printed when wifi connection is made
void loop()
MQTT_connect(); // This code utilizes MQQT transfer Protocol. MQTT stands for MQ Telemetry Transport. It is a publish/subscribe, extremely simple and lightweight messaging protocol, designed for constrained devices and low-bandwidth, high-latency or unreliable networks.
int state = digitalRead(sensor);
if(state == HIGH) {
pirsensor.publish(state);
delay(1000);
digitalWrite(ledPin, LOW); // Turn the LED on (Note that LOW is the voltage level
digitalWrite(buzzer,HIGH);
Serial.println("Motion detected!");
delay(100);
else{
digitalWrite(ledPin, HIGH); // Turn the LED off by making the voltage HIGH
digitalWrite(buzzer,LOW);
Serial.println("Motion Absent");
delay(100); // Wait for two seconds (to demonstrate the active low LED)
Adafruit_MQTT_Subscribe * subscription;
while ((subscription = mqtt.readSubscription(5000))) //Dont use this one until you are conrolling something or getting data from Adafruit IO. Here we are only controlling the LED from the toggle switch of Adfruit IO Dashboard
if (subscription == &LED)
//Print the new value to the serial monitor
Serial.println((char*) LED.lastread);
if (!strcmp((char*) LED.lastread, "OFF"))
if (!strcmp((char*) LED.lastread, "ON"))
void MQTT_connect() // This little section of code here is how MQQT Protocol sends the data to the server.
int8_t ret;
// Stop if already connected.
if (mqtt.connected())
return;
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) // connect will return 0 for connected
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0)
// basically die and wait for WDT to reset me
while (1);
Last edited by adafruit_support_bill on Wed Jan 25, 2023 8:59 am, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums
bidrohini
Re: NodeMCU ESP8266_PIR stays HIGH
Post by bidrohini »
I suggest you place the PIR and the ESP8266 not close to each other. Earlier I have read some other users facing the same problem. It happens because the PIR signal gets interrupted by the internal circuit of ESP modules.
QnBarb
Post by QnBarb »
Thank you for the advice. I've also disconnected the sensor, but the board still sending out the pin was HIGH. Do you you know why?
bidrohini
Post by bidrohini »
I can see that your PIR is connected to D2. Maybe this pin is always HIGH by default. I think you can run a couple of tests. You can disconnect everything and upload any other simple code to the board. And then measure the D2 pin to see if it is always high no matter what you upload. You can also change your PIR pin to any pin other than D2. And see if this problem still persists. It will be better if you just try a simple code first without the MQTT library. Here is a simple example featuring PIR and ESP32. I know, you are not using the same board. But you can follow the example to test.
https://www.pcbway.com/project/sharepro ... 9ccbd.html
With nothing connected to the pin, the value will 'float' and result are unpredictable.
QnBarb
Post by QnBarb »
I switched to pin D1, and it works. Thank you all.
