i2c.try_lock hangs
cagiva
i2c.try_lock hangs
Post by cagiva »
I'm using an ESP32-S3 TFT Feather with the Adalogger FeatherWing and if I call the try_lock code below from code.py, then it hangs. Could it be that the CircuitPython library is managing the I2C lock for me automatically by grabbing it before it does an I2C transaction?
import board
i2c = board.I2C()
while not i2c.try_lock():  pass
Running this code from REPL works fine though.
import board; i2c=board.I2C(); i2c.try_lock(); [hex(a) for a in i2c.scan()]; i2c.unlock()
danhalbert
Re: i2c.try_lock hangs
Post by danhalbert »
Is your first example the whole program? If not, could you post the whole program, or at least up to the point of error?
What version of CircuitPython are you using?
This works for me on a Feather ESP32-S3 running a post 8.0.0-beta.6 build, but I would expect it to work on any build. It prints "got lock" and then loops.
import board
i2c = board.I2C()
    print("failed to get lock")
    pass
print("got lock")
while True:
    pass
blakebr
Post by blakebr »
Dan,
Could these be related?
viewtopic.php?t=198129
Bruce
danhalbert
@blakebr - I don't think so; this is very simple without the extra libraries, it appears. But I'd like to see more code.
cagiva
Post by cagiva »
@danhalbert,
It turned out that it's actually hanging in the PCF8523 call.
import board
import adafruit_pcf8523
i2c = board.I2C()
    pass
print("got lock")
rtc = adafruit_pcf8523.PCF8523(i2c)  #<--- Hangs here
danhalbert
Don't grab the lock before you do`adafruit_pcf8523.PCF8523(i2c)`. Just take that code away. All our libraries take care of managing the locking themselves. They use `adafruit_busdevice`, which does the lock management.
cagiva
Post by cagiva »
Copy that. Thanks @danhalbert. 👍
blakebr
Post by blakebr »
Dan,
I put the code in the original thread.
I apologize for stepping on this thread.
Bruce
