VCC for Monochrome 1.3" 128x64 OLED graphic display - STEMMA QT / Qwiic
mikemontauk
Post by mikemontauk »
Product ID: 938
Datasheet indicates UG-2864KSWLG01 pin 28 is Supply Voltage for Display/power supply for OEL panel, but schematic shows no input to pin 28. The datasheet then indicates “1.6.2 VCC Generated by Internal DC/DC Circuit Please contact us for further information.” Is an internal DC/DC circuit used? Can VCC still be supplied up to 15V?
mikeysklar
Re: VCC for Monochrome 1.3" 128x64 OLED graphic display - STEMMA QT / Qwiic
Post by mikeysklar »
Only use 3v3 or 5v with ADA# 938 a 3v3 regulator is included along with level shifters. Do not supply 15v.
The driver chip, SSD1306 can communicate in two ways: I2C or SPI. The OLED itself requires a 3.3V power supply and 3.3V logic levels for communication, but we include a 3.3V regulator and all pins are fully level shifted so you can use with 3V or 5V devices!
mikemontauk
Than you for your input and support, but my question is assuming Pin 28 VCC of the UG-2864KSWLG01 is powered separately. I'm not using the regulators or the level shifts. I would like to know if Pin 28 VCC of the UG-2864KSWLG01 can be up to 15V as the datasheet suggests, or if the DC/DC circuit would interfere. I'm finding the DC/DC circuit a bit clandestine lol. And should Pin 6 VBAT (VDDB) be floating if VCC is powered separately?
