Raspberry Pi 4B Doesn't Boot
- talmax
Hello, so I got this raspberry pi 4B from you today When I installed raspberry pi os, and inserted the sd card and turned it on, there is no display. I tried changing the config file but still nothing. Any tips to make it show. I only see the red light. I believe I have a damaged board. It does not boot. I've tried all troubleshooting steps.
- 327476098_568696361823037_3093965545559269500_n.jpg (71.52 KiB) Viewed 152 times
- adafruit_support_carter
Re: Raspberry Pi 4B Doesn't Boot
Did you try getting the Pi to boot before adding the fan and heat sinks?
https://learn.adafruit.com/raspberry-pi ... this-first
- talmax
Hello, Carter. Yes, I have. I have tried with a different SD card and a different power supply
- talmax
adafruit_support_carter wrote: ↑Wed Jan 25, 2023 1:48 pm Did you try getting the Pi to boot before adding the fan and heat sinks?
- talmax
Could you do a replacement?
If the Pi did not boot prior to attaching the fan and heat sinks, why were they then added?
- talmax
I saw it power up didn't attach anything then attached everything and thats when i realized that it was not booting. Don't know what you are accusing or coming from but I would like a replacement
- talmax
I would just like a replacemment.
As support, if an item isn't working it should be refunded or replaced as per adafruit policy.
If you could send me an email for the replacement even better.
In general, anything attached to a Pi's GPIO pins is considered warranty voiding:
https://learn.adafruit.com/raspberry-pi ... ng/warning
If you disconnect the fan and try this check:
https://learn.adafruit.com/raspberry-pi ... ck-3110723
what behavior do you see?
- talmax
Hello, it just flashed green one time for a millisecond and it disappears. Doesn't do anything else. I initially tried powering it on without any accessories like mentioned before. It just stays at Red. So, it wasn't cause of the fan.
I would really like to not have any more complications, and ask for a replacement.
- talmax
I tried every troubleshooting step, and no progress. I've tried it without the case, with the case, with the SD Card, Without the SD Card. I even tried with a different SD Card, and a different power supply, and so, really all I need is a replcement to have a functional raspberry pi.talmax wrote: ↑Fri Jan 27, 2023 1:10 pm Hello, it just flashed green one time for a millisecond and it disappears. Doesn't do anything else. I initially tried powering it on without any accessories like mentioned before. It just stays at Red. So, it wasn't cause of the fan.
If this is something that is not possible. I would like to elevate the case, because it is not users fault rather raspberries / the vendor.
Replacements are not possible due to inventory shortages. We can only offer a refund.
Send an email to [email protected] with a link to this thread and your order number and they can refund you for the Pi.
