Anyone have an example of accepting input from a user via the web browser?
For example, exposing a text box to the user and then showing what was typed on a small display.
Accept user input with adafruit_httpserver
- greenleaf
- greenleaf
Re: Accept user input with adafruit_httpserver
I can see from the NeoPixel example that you can change request parameters in a URL:
https://docs.circuitpython.org/projects ... ixel-color
Wondering if there's a way to enable direct user input via a form...or code to take what's in the form and submit it as a URL parameter?
- neradoc
Hi, here is an example with a text field.
https://gist.github.com/Neradoc/fd29d5a ... 9345027930
If the mdns works on your network it should show up as http://text-setter.local:8080/
When you press enter it sends the text and prints it to the REPL. The code to show the text on a display will be easily added from the examples of whatever display you are using.
Files should be placed like that (the blinka favicon is optional) Since it uses os.getenv/settings.toml, it requires Circuitpython 8.0.0 beta 6 or later, but you can change the connection code if you need to.
Here is the code (the same as the gist above).
code.py
index.html
code.py
# SPDX-FileCopyrightText: 2023 Neradoc
"""Press a button on the web page to cycle the colors"""
import board
import mdns
import microcontroller
import socketpool
import time
import wifi
import os
from adafruit_httpserver.server import HTTPServer
from adafruit_httpserver.response import HTTPResponse
from adafruit_httpserver.mime_type import MIMEType
MDNS_NAME = "text-setter"
PORT = 8080
ROOT = "/www"
# MDNS
mdnserv = mdns.Server(wifi.radio)
mdnserv.hostname = MDNS_NAME
mdnserv.advertise_service(service_type="_http", protocol="_tcp", port=PORT)
# wifi
wifi.radio.connect(
os.getenv("CIRCUITPY_WIFI_SSID"),
os.getenv("CIRCUITPY_WIFI_PASSWORD")
print(f"Listening on http://{wifi.radio.ipv4_address}:{PORT}")
pool = socketpool.SocketPool(wifi.radio)
server = HTTPServer(pool)
# server routes and app logic
@server.route("/")
def base(request):
"""Default reponse is /index.html"""
print("/ -> index.html")
with HTTPResponse(request, content_type=MIMEType.TYPE_HTML) as response:
response.send_file(f"{ROOT}/index.html")
@server.route("/text")
def base(request):
# receive a text
the_text = request.query_params.get("the_text", "")
print(f"Received: {the_text}")
response.send("ok")
# start and loop
IP_ADDRESS = wifi.radio.ipv4_address or wifi.radio.ipv4_address_ap
server.start(host=str(IP_ADDRESS), port=PORT, root_path=ROOT)
while True:
server.poll()
time.sleep(0.01)
<!doctype html>
<html lang="en">
SPDX-FileCopyrightText: Copyright 2023 Neradoc, https://neradoc.me
<head>
<meta charset="utf-8"/>
<link rel="icon" href="/blinka.png"/>
<title>Button</title>
<script>
function send_text(field, event) {
console.log(field.value)
console.log(event)
if(event.keyCode == 13) {
fetch(`/text?the_text=${field.value}`)
</script>
</head>
<body>
<div>Press enter to send: <input type="text" onkeyup="send_text(this, event)"/></div>
</body>
</html>
- greenleaf
Thanks, this is rad! Much cleaner than what I came up with on my own. This outputs the message to a little OLED display on my desk:
from config_secrets import secrets
import json
import socketpool
import wifi
import board
import busio as io
import adafruit_displayio_ssd1306
import time
import terminalio
import displayio
from adafruit_display_text import label, wrap_text_to_lines
from adafruit_httpserver.request import HTTPRequest
ssid, password = secrets['WIFI_SSID'], secrets['WIFI_PASSWORD']
print("Connecting to", ssid)
wifi.radio.connect(ssid, password)
@server.route("/")
def base(request: HTTPRequest):
Serve the default index.html file.
response.send_file("index.html")
displayio.release_displays()
i2c = io.I2C(board.SCL, board.SDA)
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=128, height=64)
# Make the display context
splash = displayio.Group()
display.show(splash)
color_bitmap = displayio.Bitmap(128, 64, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0xFFFFFF # White
text_area = label.Label(terminalio.FONT, text="Ready to receive.", color=0xFFFF00, x=0, y=10)
splash.append(text_area)
@server.route("/index.html")
def send_message(request: HTTPRequest):
message = request.query_params.get("message")
message = "\n".join(wrap_text_to_lines(message, 20))
text_area.text = message
response.send('''
<html>
<head><title>Meow!</title></head>
<body>
<style>
body {
background-image: url('ninjacat.jpg');
</style>
<div style="width:800px;margin: 0 auto">
<!-- BEGIN -->
<center>
<br><br><br><br><br><br><br><br><br><br><br><br><br><br><br><br>
<form method="get" action="/index.html">
<input type="text" id="message" name="message"><br>
<input type="submit" value="Send a Message"><br>
</form>
<h2 style="color:green;">Message Sent!</h2>
</center>
<!-- END -->
</div>
</body>
</html>
print(f"Listening on http://{wifi.radio.ipv4_address}:80")
server.serve_forever(str(wifi.radio.ipv4_address))
while True:
pass
- neradoc
Hey I realized that with my method the message is transmitted url-encoded, which would need to be decoded (%20 and all that). So instead I rewrote it to use POST with a json-encoded body, and while I was there I integrated the display text (also making it work on my FunHouse for tests) and I added a loading animation and confirmation ☑️ or error ❌️ icon.
I updated the gist above with it.
- greenleaf
Nice, thanks for the update. I'd been using str.replace() to strip out those URL encoded characters. The JSON solution is better!
