MCP23017
sleepingalex24
MCP23017
Post by sleepingalex24 »
I have one of your MCP23017 i2c expansion boards and am attempting to use it with an HX711 loadcell board. This board requires very fast reads and writes and I believe it's not working with the MCP23017 because of how slow the mcp.digitalRead and mcp.digitalWrite methods are. I have attached a demonstration of how much slower they are below:
float j;
mcp.begin_I2C();
pinMode(3, OUTPUT);
mcp.pinMode(4,OUTPUT);
Wire.setClock(400000);
mcp.digitalWrite(4, LOW);
digitalWrite(3, LOW);
delay(5000);
j = micros();
mcp.digitalWrite(4, HIGH);
j = micros() - j;
Serial.print("TOTAL TIME1: ");
Serial.println(j);
j = micros();
digitalWrite(3, HIGH);
j = micros() - j;
Serial.print("TOTAL TIME2: ");
Serial.println(j);
The output is as follow:
TOTAL TIME1: 276.00
TOTAL TIME2: 8.00
Is there any way to speed up the reads and writes of the MCP23017 board or is this just a limitation of the hardware?
Thank you!
Alex
adafruit_support_carter
Re: MCP23017
Speeding up the clock speed is about the only thing that might work. But in general, doubt this is achievable. Same issue as here:
viewtopic.php?p=954642
Checkout the NAU7802:
https://www.adafruit.com/product/4538
sleepingalex24
Re: MCP23017
Ah got it, thank you! Gonna have to approach this differently.
