I plan to use a protoboard to connect a standalone esp32 to an RGB Matrix. I only saw instructions for pin connections to Arduino boards on the tutorial https://learn.adafruit.com/32x16-32x32- ... oto-shield. Which pins from the matrix should be connected to which on the esp32. I'll attach schematics of both below.
I'm somewhat new to all this and may have bitten off more than I can chew.
How to connect esp32 to 32x64 RGB LED Matrix
- sreg
- ESP32 pins
- ESP32-DEVKIT-Pin-mapping.jpg (161.37 KiB) Viewed 234 times
- Matrix pins
- led_matrix_socket2.png (6.09 KiB) Viewed 234 times
- mikeysklar
Re: How to connect esp32 to 32x64 RGB LED Matrix
Since you are somewhat new to this I would recommended making a course change.
Using an ESP32 board for WiFi and a 32x64 RGB Matrix can be super easy, but not with the board you are trying to use.
The MatrixPortal would be really easy as it is designed for exactly this.
https://www.adafruit.com/product/4745
- LGarber
OMG Mikey, you just saved my life (well... at least a ton of wasted time in my life)! I was heading down the same path as @sreg. How did I not know about the MatrixPortal?!?! Thank you! ...Larry
