I’m not optimistic on this, but is there a way to turn off the bright power LED on the SHT45? If not, is black electrical tape my best option?
Thanks for the help, this is my first project.
SHT45 LED
- bidrohini
Re: SHT45 LED
There is no straightforward way to Turn off the LED. Using black electrical tape to cover the LED may be the best option to reduce its brightness. This is a simple and inexpensive solution that should be effective in reducing the LED's brightness while still allowing you to see the status of the device.
- adafruit_support_carter
Re: SHT45 LED
Yep, the LED is directly connected to power. There is no way to control it via software. So will need to do something manually, like tape, etc.
