MS8607: cannot import name 'const' from 'micropython'
unwttng
Post by unwttng »
Hi there,
I'm trying to get set up with the MS8607 sensor on a Raspberry Pi Zero W. I've followed this guide https://learn.adafruit.com/circuitpytho ... spberry-pi to get it set up with CircuitPython / Blinka and then run
sudo pip3 install adafruit-circuitpython-ms8607
as per this guide: https://learn.adafruit.com/adafruit-te- ... cuitpython.
However, when I try importing the adafruit_ms8607 module in python3 I get the following error:
Code:
import board
import busio
from adafruit_ms8607 import MS8607
Error:
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python3.9/dist-packages/adafruit_ms8607.py", line 38, in <module>
    from micropython import const
ImportError: cannot import name 'const' from 'micropython' (/usr/local/lib/python3.9/dist-packages/micropython.py)
I've double-checked that I didn't miss any of the setup steps, I2C and SPI devices are available on the Pi. Not sure where else I might have gone wrong?
Thanks for any help!
dastels
Re: MS8607: cannot import name 'const' from 'micropython'
Post by dastels »
It looks like const can't be found in /usr/local/lib/python3.9/dist-packages/micropython.py. You can have a look in it to verify whether of not it's there.
Is micropython.py up to date?
unwttng
Post by unwttng »
I'm glad I looked! micropython.py seems to be totally empty, though the file itself does exist. I'm now trying to work out which part of the Adafruit guides I linked was supposed to perform the installation of micropython since it seems to have failed.
unwttng
Post by unwttng »
I'm going to have to assume that somewhere along the way that file got corrupted: I since tried totally re-imaging the Pi Zero W and running through the same steps and this time I ended up with a valid micropython.py file and a working sensor interface. Thanks for the help!
dastels
Post by dastels »
Weird.
Glad it's working for you!
