using Arduino uno data logger on Adruino nano
maknop
Post by maknop »
I am using arduino uno data logger shield (https://learn.adafruit.com/adafruit-data-logger-shield) without any issue.
I would need to use it with a arduino nano. could someone give me details about which pin of the shield I need to connect to the arduino nano?
Regards
Maximilien
Re: using Arduino uno data logger on Adruino nano
You will need to connect GND and 5v to power the shield.
You will also need MISO (CIPO), MOSI (COPI) and SCK for the SD card. These pins can be found on the 2x3 pin ICSP header.
And you will need SDA and SCL for the real-time clock.
The shield follows the Arduino UNO pinout. https://content.arduino.cc/assets/A0000 ... pinout.pdf
Note that the ICSP header on the Nano is flipped relative to the UNO: https://content.arduino.cc/assets/Pinou ... latest.pdf
maknop
Post by maknop »
Thank you very much
Return to “Other Arduino products from Adafruit”
