UF2 Bootloader v2.0
Model: Raspberry Pi RP2
Board-ID: RPI-RP2
Adafruit CircuitPython 7.3.3 on 2022-08-29; Adafruit Macropad RP2040 with rp2040
Board ID:adafruit_macropad_rp2040
Strangely enough, the code.py is not affected by this. It does mean though that every so often I need to delete the empty files, and reupload them to the device from my computer. After losing them a few times now, I finally have backups.
I haven't run into this issue for the first long while since getting it in the Adabox. It's happened to me now at least 4 times since the new year. Not sure if there's any additional info I can give, or debugging steps you can provide
