adafruit_display_shapes.polygon: arguments "colors" and/or "close" result in error messages
eddtrettel
Post by eddtrettel »
I'm running "Adafruit CircuitPython 8.0.0-beta.6-28-g6013cde6a on 2023-01-05; Adafruit Matrix Portal M4 with samd51j19".
I've successfully used every argument in every shape in the adafruit_display_shapes library, with the exception of "colors" and "close" in Polygon.
When I try to use those I get a:
File "code.py", line 65, in <module>
TypeError: unexpected keyword argument 'close'
Same for "color".
Below is a sample case I made to demonstrate the issue. It gets interpreted (and generates a shape on the LED matrix) for those instances that exclude used "color" and "close".
I've read the doc and these are shown as optional parameters there.
I've also read the source code for polygon on github and in the preamble these also appear to be optional.
I've done a binary compare of the polygon.mpy on the Matrix Portal with the same file in the 8.0.0 beta library and they are identical, so it's not a case of the one on the Matrix Portal being out-of-sync.
Any help that can be given would be appreciated. Here's my sample code. If you can get "colors" and "close" to work, please let me know how. Thanks.
from gc import enable, collect, mem_free
from time import monotonic, sleep
from displayio import release_displays, Bitmap, Palette, TileGrid, Group
from terminalio import FONT
from random import randint, uniform
from adafruit_matrixportal.matrix import Matrix
from adafruit_display_shapes.polygon import Polygon
enable()
release_displays()
matrix = Matrix(width=64, height=32, bit_depth=4)
bitmap = Bitmap(64, 32, 16)
palette = Palette(16)
tile_grid = TileGrid(bitmap, pixel_shader=palette)
group = Group()
matrix.display.show(group)
color_dict = dict(
    black=0x000000,
    blue=0x0000FF,
    coral=0xFF4040,
    cyan=0x00FFFF,
    green=0x004000,
    grey=0x404040,
    lime=0x00FF00,
    magenta=0xFF00FF,
    maroon=0x400000,
    navy=0x000040,
    olive=0x404000,
    purple=0x400040,
    red=0xFF0000,
    teal=0x004040,
    white=0xFFFFFF,
    yellow=0xFFFF00,
palette[0] = color_dict["black"]
palette[1] = color_dict["white"]
palette[2] = color_dict["red"]
palette[3] = color_dict["lime"]
palette[4] = color_dict["blue"]
palette[5] = color_dict["yellow"]
palette[6] = color_dict["cyan"]
palette[7] = color_dict["magenta"]
palette[8] = color_dict["coral"]
palette[9] = color_dict["grey"]
palette[10] = color_dict["maroon"]
palette[11] = color_dict["green"]
palette[12] = color_dict["navy"]
palette[13] = color_dict["olive"]
palette[14] = color_dict["teal"]
palette[15] = color_dict["purple"]
while True:
    outlinex = palette[randint(1, 15)]
    v1 = (randint(0, 63), randint(0, 31))
    v2 = (randint(0, 63), randint(0, 31))
    v3 = (randint(0, 63), randint(0, 31))
    v4 = (randint(0, 63), randint(0, 31))
    listx = [v1, v2, v3, v4]
    polygon = Polygon([v1, v2, v3, v4], outline=outlinex)
    group.append(polygon)
    polygon = Polygon(points=listx, outline=outlinex)
    polygon = Polygon([v1, v2, v3, v4])
    polygon = Polygon(points=listx)
    polygon = Polygon([v1, v2, v3, v4], outline=outlinex, close=True,colors=1)
    input("post append")
code.py
here's the code, with tabs for indent
(2.09 KiB) Downloaded 2 times
Reason: Add code tags
dastels
Re: adafruit_display_shapes.polygon: arguments "colors" and/or "close" result in error messages
Post by dastels »
Make sure you have the latest version of the display shapes library (and all of them for that matter).
eddtrettel
Thank you, dastels! I upgraded the library from the 2023 01 05 version to the 2023 01 27 version and can now use the "colors" and "close" parameters.
Now I'm stymied in how to get it to fill the polygon. In the documentation at https://docs.circuitpython.org/projects ... ml#polygon in the "colors" parameter it makes reference to filling the polygon, but doesn't say how to do this.
I've tried setting "colors" to 1,2,3,4,5,6,7,8,9 and it has no effect. I had "close" set to True to make it draw a closed shape and not an open one.
Perhaps this was never implemented as a feature. The other shapes (circle, square, etc) all have "fill" as an exclicitly named option.
Thanks again for your help.
Best regards,
E.T.
dastels
Post by dastels »
As you see, close & colors were just recently added to Polygon, so it may be a work in progress.
eddtrettel
Thank you again for the insight into this. I'll hold off until other parameters are added, if ever.
I have to tip my hat to the folks who coded the "shapes" library. It's remarkable.
We can consider this item closed.
Best regards,
E.T.
